  New Posts New Posts RSS Feed - 63 American Skier 198 Sabre engine
Mdn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mdn Quote  Post ReplyReply Direct Link To This Post Topic: 63 American Skier 198 Sabre engine
    Posted: June-18-2018 at 3:27pm
My engine runs cold and was going to change the thermostat. I was surprised to find that the Thermostat cover has two domes . On the pump side there is a disc that pivits like a choke on a carb. Under the second dome there was a disc with a hole in it. Is anyone familiar with this setup.?
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 3:38pm
Mike,
What do you consider cold? I've never been into a Sabre cooling so it will be interesting to hear if someone has and can explain how it works.
Mdn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mdn Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 4:05pm
About 110 degrees originally I thought someone had removed the thermostat
Mike
