G boat problems? |
Posted: June-18-2018 at 12:37pm |
Has anyone heard about prop shaft breaking problems CC is having? I know of one up here that's on it's 5th shaft since last season. I wonder if I need to go over to the dealer and see if they know how to do an alignment!
Yea big topic on PN in the past still happens every now and then,but 2015 I think were the big years. They are breaking between the strut and prop.
shierh
sounds like shaft size isnt correct. Bigger engines, bigger props etc. Wake board tanks with lots of load.
They increased the shaft size and it still happens. Google planet nautique g23 drive shaft issues if you want to see pictures. I have a theory that it's the crappy music they play while surfing, prop says I'm outa here......
5th shaft a season up there must average every time they go out,ice chunks caught between hull and prop? |
bb12
Senior Member Joined: March-24-2009 Location: Kansas, USA Status: Offline Points: 355 |
Yep.. I’m on one of the Nautique Owners Facebook pages and it seems somebody is posting about this happening every few weeks.
Matter of fact...this was posted this morning. |
1989 Ski Nautique 2001
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
I believe that all G boats now have 1-1/4” shafts- the 550hp SC still has the 1.5:1 v-drive but the lower engine options have 2:1 reduction and they all need that big shaft with the amount of torque they’re putting to the prop. I think the very early production boats may have used 1-1/8” and the fix is to upsize.
Gary,
Thanks, I was just over on PN and the 1&1/4"s are breaking too. Same spot were the key way begins weakening the shaft. Maybe they should try forgoing the keyway and just lap the prop to the shaft. |
I thought it looks like 1/4 “ out from the key way start but not seeing one in person it’s just speculation. Must be something up, the people providing the shafting should know what they are doing, something they have never had happen before, hp, weight, girlie tunes...
General Propeller makes the shafts but they make them per the customers specs.
shierh
There are different alloys that are stronger, not sure how good etc.
General makes good stuff. they made my replacement shaft. Took my old one over to them with the prop and coupler and they made new shaft and reworked my prop. |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6147 |
The original issue (which ended up as a recall) was that they spec'd a 1-1/4" shaft but instead of getting Acme to design a specific propeller they just turned the shaft down to a 1-1/8" taper so all of that extra shaft strength was lost where the taper connected to the rest of the shaft.
They swapped them all out to the correct shaft and propeller and they are still having issues? That sucks. |
What prop (dia. and pitch) are they putting on the 550hp?
They probably need to go with these. Not only will they be able to eliminate the shaft, they'll be able to get rid of the rudder and steering wheel as well.
https://www.thrustmaster.net/azimuth-thrusters/z-drives-for-the-inland-waterways/ |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10644 |
Maybe you should take your galvanic corrosion chart over with you Pete, and you could see if they're using some inferior SS screws in the strut along with explaining the finer points of galvanic corrosion of dissimilar metals. |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2840 |
Those Z-Drives are pretty cool. We've had a couple of vessels with those and the maneuverability is off the charts. Great for dynamic positioning, too. JQ |
Bruce, I sure agree the G's need it! |
It would be interesting to know if the metallurgical failure is torsion only or is there some cyclic bending stresses from the prop overhang. Possibly a collar between strut & prop would reinforce it.
baitkiller
I would try spoon cutting the key way. Sure couldnt hurt. My little 1 incher is spoon cut with a pinned key but the machinist is a friend. Does anyone know what shafting is in use? The Aquamet 22 though pricey is pretty dang tough stuff and usually specified for higher torque applications. I kind of doubt thats being used but I really have no idea.
Why would the "bean counters" allow the PA to buy the good stuff for a 200K boat? |
tryathlete
What’s wrong with splines? Keyway takes a lot of material out of the shaft. |
A spline removes even more material plus it isn't a tight fit like a taper. I think MC uses them because their owners would be mentally challenged to lap a prop to the shaft. |
tryathlete
Splines are ridges or teeth on a drive shaft that mesh with grooves in a mating piece and transfer torque to it, maintaining the angular correspondence between them. ... An alternative to splines is a keyway and key, though splines provide a longer fatigue life.
tryathlete
A spline is a multiple keyway. Since you are spreading the torsional forces over multiple areas, you can decrease the induced stresses. This is shown in Machine Design texts like Shigley and Mischke.
The keyway isn’t supposed to transmit torque but when most dealers cannot properly lap in the prop to the shaft, I like splines better. |
Sounds like you would be a perfect candidate for owning a MC. |
tryathlete
Pete
They make a good boat CC makes a better one though!😂 |
Bravo
tryathlete
Turning a 1-1/4” shaft down to 1-1/8” at the End of the shaft and expecting nothing bad to happen shows some seriously weak judgement at some level, regardless of keyway/splines. 550 HP is a crapload of power! I wonder what the torque is on that beast.
DVskier
G series boats are wrecking shorelines everywhere they are operated. I have no sympathy for the owners who experience broken prop shafts. Usually operated while surfing with a beer laden crew who is jamming rasta music at deafening sound levels.
Legislation certainly has to be coming as our shorelines continue to erode. It may be different where you live. |
tryathlete
Indeed the erosion problem is real. Any large boat driving bow up (cabin cruisers certainly outnumber wake boats) is going to erode the crap out of shoreline property. I get a bit nuts when my wife drives “slowly” in an effort to “take it easy”. No wake or on plane is the right way to motor.
