Starting problem |
Author | ||
Brock7
Newbie Joined: June-17-2018 Location: Colorado Status: Offline Points: 7 |
Posted: June-17-2018 at 6:22pm |
I have a 96 Correctcraft Sport Nautique that has about 350 hours on it. We took it out and had 4 people ski without any problem starting the engine. After we took a little break the boat started and quickly petered out. The engine then wouldn’t start but it would turn over and sound like it was about to start and then wouldn’t. Any idea of what is wrong?
SNobsessed
Does it have Peo-tec ignition? They are known to fail with heat soak.
gt40KS
Which engine model ... GT40 efi or carbureted ? Ford or Chevy power?
JCCI
1995 Ski Nautique GT40 |
Brock7
It is a Ford 351 PCM engine so it is fuel injected
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10643 |
Just to start simple...................is your safety lanyard plugged in or did it maybe get knocked loose?
Brock7
The safety lanyard is plugged in
Less simple ..............can you hear the fuel pumps run when you turn the key on?
You can read about fuel pump and ECM relays in this thread in the link below. Either relay being bad will keep the fuel pumps from running If you look at the diagram in the link you'll find breakers for the fuel pumps and ECM that you can check too. link |
Got gas in the tank ?
Brock7
There is plenty of gas in the tank and I can hear the fuel pump when the key is turned
Got spark?
We're still on the easy stuff |
got a service manual?
Click the link and you will. 301 wonderful pages of reading. link You could spend some time reading this thread too Poor man's GT40 diagnosis |
Brock7
Yes we have spark we also replaced the spark plugs last fall
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4232 |
Brock, when the engine died you said it "quickly petered out". Did it surge and almost die and surge again, or did it just start, run 5 seconds, and die? And, did you again try to start it hours later once it had completely cooled down?
On the kill switch lanyard question - it's worth removing the lanyard and holding the switch in all the way with your thumb while trying to start, just to make sure. I had a lanyard that just barely engaged the switch, then didn't quite engage it, had to change out the switch. |
vwg98sn
Newbie Joined: July-14-2017 Location: Alabama Status: Offline Points: 1 |
From what it sounds like, you need to replace the ECM relay. Very same problem with my 98 gt 40. Very inexpensive to replace, and easy fix.
With key and ignition on, you can try tapping on the relay and listen for a "buzz" of the fuel pump to charging. |
gt40KS
We are all assuming at this point that you have the GT40 engine since you say it is fuel injected. Just to be clear, CC had at least a couple of Ford options for several years in the 90's, one of which was a 260hp carburated 351. The only one (Ford 351) to my knowledge that was fuel injected in 96' was the GT40: GT40 Any updates on progress? |
JCCI
Brock 7 hasn't logged on since 6/18 Joe
Maybe he figured this out, maybe he didn't. Maybe he's halfway through the manual. His replies were just chock full of info |
Maybe he took it out again
Could be still out there stuck |
Yes, and needs a rescue? BTW, does anyone know who this is? One of us??? |
Looks like something Larry would create
Gary, That did cross my mind but there are too many details that look real. |
Looks like the real thing!! White River near Broad Ripple Park Indiana |
Duane in Indy
Looks like the real thing!! White River near Broad Ripple Park Indiana[/QUOTE] Zach's stomping grounds |
1978 Mustang (modified) |
63 Skier
Oh, they went over the dam. I thought they were headed upstream, just needed a few more ponies to get up and over!
SNobsessed
An anchor would have been helpful there.
Brock7
I can here the fuel pump buzzing without doing anything so does that indicate whether or not that needs to be replaced?
Brock, Have you had a chance to take a look at the manual and the gt40 diagnosis thread? Yes, more details would be great so we can try to help like the fuel pressure at the rail?
