Went ahead a bought it.. |
Author | |||
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Posted: February-17-2018 at 8:45pm |
Hey guys just picked up a 1983 SN which looks great compared to the others I looked at priced from $4500 to $5500...
I got it for $1700 due to the tire blew and broke the springs(another post), on the way home. I knew it had bad floor on pass.side, but how is the best way to get into that area? I used a cutter tool and cut out a square( the glass looks to be 1/4" or better). The carpet must glued in with fiberglas as I can't get it up at all.. What is a good tool to use in that floor? |
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 928 |
We used a circular saw set to the thickness of the floor to cut out. If you aren’t redoing your stringers just don’t go too deep. That plywood should just rip up. If getting it from the wall and want to get closer than the circular will allow, go with an angle grinder.
samudj01
Oh and congrats. Pics please!!
John, I made this suggestion several days ago. Have you had the chance to do some reading??
jterr
I have read so much I'm bout cross-eyed.. |
jterr
The last I read was the 1980 restore thread .. How did you get the carpet out in one piece????
jterr
Soon as I figure out HOW?? |
John,
For picture posting, ether use the "post reply" or click on the "full reply editor" icon Then you will get an icon of a tree with an up arrow. Clicking it will bring up a browse box allowing you to select anything off your computer. |
jterr
jterr
John,
Glad you were able to figure out the posting of pictures. Keep them coming with your progress with the 2001. Have you been able to check the stringer condition? Regarding getting the carpet out in one piece, it's nearly impossible. Besides saying the old for a rough pattern, new carpet should be considered. |
jterr
Duane in Indy
Short answer: no
I would want it sealed up |
1978 Mustang (modified) |
John,
Post a picture of the log inside the hull. To me, it looks like a PO tried to seal/bed it back in after it broke loose from the hull. |
Duane in Indy
The soft floor appears to be the tip of the iceberg. Rare that the rot stops there. Don't be surprised if the stringers are rotten too. Mine were.
jterr
jterr
Started cutting more floor out and both stringers up front passenger side are rotten
Gonna call some places around here that do boat work and price out before I decide to do it myself |
jterr
Will a 71 Ski pole fit this boat or can the eye be removed and put on this pole??
Hollywood
Thanks(1)
71 is a smaller diameter pylon. It will not be a direct fit.
I have an 85 pylon complete and in good shape available. Get me your phone number in a PM and I'll send pics. |
jterr
Question on stringers as I can't see pics for now. When the top of stringer is all rotted out, how do you now where the cutouts are?
As I started cutting out the floor in the 83 I haven't found wood yet, just 1/4" thick fiberglas then dirty wet stuff and foam.... |
The wood may be rotted but the old glass covering the stringers should be intact. |
jterr
I keep seeing pictures of boats with floor/stringers removed, but can't seem to find a 83. What years would be close to the same?
jterr
I saw the sides of the stringer but there was no glass on top, |
JoeinNY
82-88 |
