  New Posts New Posts RSS Feed - 1976 Ski Nautique misc parts---MAKE OFFER
iamabuyer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Topic: 1976 Ski Nautique misc parts---MAKE OFFER
    Posted: February-06-2018 at 12:31am
My 1976 Ski Nautique was parked near a storage shed that caught fire. It is no longer seaworthy so I have stripped most everything off the hull. Many good parts. I do not need these parts..........NO REASONABLE OFFER REFUSED.........!!!
Trailer...$350
Velvet Drive transmission...$400
Lake water inlet with screen and elbow...$5
Lifting eyes...$20 pr
Hatch cover...$5
Fin...$50
Strut...$50
Prop shaft, stuffing box and coupler...$50
Steering assembly with cable (17') and wheel...$50
Control assembly w/cables 17'...$50
Bow light...$10
Engine cover w/hinges
Flywheel, damper plate, dust cover for 351W
Bellhousing 351W
Crank shaft 351W
rolleronariver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 4:39pm
Are the exhaust manifolds in good shape still and will they fit on my 351w in my 92 sport?
92 Sport nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2018 at 6:15pm
Yes, good condition. Yes, they fit 351W. I do not know about clearance issues between engine and engine cover on your boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 10:54am
Would you consider finding someone to pressure test them for any leaks in the water jacket?
92 Sport nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 1:03pm
I tested them on the engine before I removed them. No leaks, no overheat, no water in oil.
I can get them tested locally if you want to pay for the testing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:18pm
How much are you going to ask for them if they test ok?
92 Sport nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:22pm
I question a "test" while on the engine. On the engine you can't see inside the exhaust cavity!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:30pm
My thoughts exactly. I'm really leaning towards buying new considering the cost of the engine rebuild if they fail. This is why I am asking about a pressure test.
92 Sport nautique
illiniball2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:35pm
How much for the T-handle drain plug?
Beer is my friend
87 Dominique
67 Starflite available
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:37pm
They are worth $100 each just to have as spares. The shipping will kill ya. Maybe you should buy new locally?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolleronariver Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:39pm
I'll order some off of ski dim then. Thanks for your time though!
92 Sport nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:48pm
$15 for plug and receiver set
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:51pm
Neil,
I highly recommend pressure testing the manifolds if you want to sell them. Ones with leaks really aren't even good are spares. Do it yourself. Make a block off plate for the top where the riser is bolted on, fill them with water and add compressed air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2018 at 2:53pm
PM sent
Beer is my friend
87 Dominique
crescentcorp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crescentcorp Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2018 at 3:44pm
Would like to buy the ski pylon (tower) if available, and the back lift ring set if its complete. Thanks, Cliff
mollyronnie2015 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mollyronnie2015 Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2018 at 8:22am
Do you have the plexy glass that’s holds the Speedos?
2011 Mastercraft Prostar 190
1973 Ski Nautique
1973 Kachina Jet Boat
1990 Ski Nautique
peteohboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peteohboy Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2018 at 2:33pm
I'm interested in the 5-gauges, 1-tach, and trans. cooler. Are they still available?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2018 at 5:50pm
If Neil's doesn't work out, most will cut their own. If you do, I highly recommend using polycarbonate and not acrylic (trade slang "plexy glass") since acrylic is brittle and breaks.
mmfarmer1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmfarmer1 Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2018 at 9:14am
I will take the control assembly with cable if you still have it?
fedexrc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fedexrc Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2018 at 8:41pm
hi, i need the windshield frame, without glass, can you take out the windshield glass? i will pay $200 and ship to argentina
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2018 at 8:59pm
I don't have any idea how to ship to Argentina. Sorry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mollyronnie2015 Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2018 at 9:27am
We received the Speedo brackets very quick. This will work perfect and our father is very happy as well. Been looking for one for years.
1973 Ski Nautique
1990 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote peteohboy Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2018 at 4:39pm
Got everything that I had Purchased from you in great condition and in a timely manner!
Really enjoyed dealing with you and I might be interested in your exhaust manifolds once
I"ve done a little more research.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2018 at 8:13am
Sorry for the thread jack - I have one that is available. PM me
'85 BFN (equity partner)
'96 Sport Nautique - sold.
'83 2001 Ski Nautique - sold.
'71 HM Mustang - re-homed
'56 Chris Craft Caviler - Available for purchase
Matt lutz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt lutz Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2018 at 8:44pm
I want the rudder assembly ..do you still have it ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2018 at 9:36pm
The rudder assembly is available.
danloprich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danloprich Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 11:48am
I realize it has been awhile from your original post, Do you happen to have at least one of the spedo gauges? How about the Prop?
76 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 12:52pm
The speedos are gone. I do have a 4 blade prop. I just got it back from the local prop shop. I had them check and balance it. I have not run it. It is OJ 13x13 cup
relake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote relake Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 3:37pm
Trailer still available?
Post Options Post Options   Thanks (0) Thanks(0)   Quote iamabuyer Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2018 at 3:54pm
Yes trailer is available. All lights work. Good tread on tires.
Copyright 2019 | Bagley Productions, LLC
