DIY Engine Work |
Nautique2001
Grand Poobah Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Posted: February-18-2017 at 3:11pm |
I'm curious how many GT-40 experts are on this site. There a folks who I know can tear apart a boat, rebuild the floor and engine. There are people that can troubleshoot basic issues and make necessary repairs with confidence. And then there are people who change the oil and drop their boat off at their local Correct Craft dealership for work, like me.
I've studied the PCM manual and read tons of postings on CCF regarding GT-40 engine issues. What I have learned is that symptom could be ten different fuel or electrical parts. Some parts are $1.00 and some can be $500+. I know the rule of thumb is to not start throwing new parts into a motor, as it can get costly. I've had one minor gremlin with my GT-40 I've been trying to square away for five seasons. My boat has had two tune-ups by Nautique and the flipping issue is still there. Here's my issue and this is what's been done: After about 20 minutes of use, I put the boat in gear. The RPM's will drop and almost stall, but is never has stalled. Sometime under this condition I gun it (while in gear) and there will be a minor hesitation then it accelerates perfectly fine. This doesn't happen all the time. Only maybe 3-4 times during a two hour period. The engine always idles smoothly and I have no issues with top end, approx 44.5 MPH. Starts right up, no issues. This is what's been done / replaced by Correct Craft: Spark plugs Spark plug wires Distributer cap Fuel relays Fuel filter Fuel hose in FCC Throttle position adjustment Fuel pressure and vacuum checked Battery & battery connectors replaced From what I've been reading, I think I may have found the possible cause. I plan on ordering the following parts: Fuel Pressure Regulator Throttle Position Sensor Not sure if the engine is running lean, My old man and I pulled the plugs in the fall. He thought they looked like they were running hot. I took a couple of photos and I'm not sure if anyone can tell by looking at photos. Let me see if I remember how to post! Any advice would be helpful. Thanks -Ken |
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
The idle air control valve and the fuel relay are also two parts maybe worth changing. The relays are 20 bucks and the Idle air control value can be bought off Amazon or from an auto parts store for around $50
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1796 |
I kind of like the IAC idea. Your problem is a little tough to solve because it's kind of minor. Your marina isn't throwing major parts at it but I don't think they're as knowledgeable as the folks here.
I got the stalling vapor lock bugs out with LP fuel pump. Once you get the bugs out you're going to love the reliability. It's an awesome engine with a beautiful torque curve. |
lewy2001
Ken has the dealer ever put a code reader on to check if there were any stored codes???
When it near stalls does it smell like it is running rich ??? |
Nautique2001
The Nautique tech told me this engine doesn't have any way to send and receive trouble codes. Is this true? Can I buy something to hook up and receive codes that may diagnose this issue?
No fuel smell during hesitation. I think it's starving for fuel when it's hesitating. The plugs look a bit like it's running lean. Thanks for all the ideas and feedback. I'm determined to fix this! |
Here is the one you need- here might want to look for and order an extension cable too.
Nautique2001
That's pretty cool. I've never used one before. Will it somehow tell me what's happening, whether it's lean, rich, electrical issue, etc? Will it help determine what part I need to replace? I'll definitely order one. Ken
I'm not familiar with obd 1 systems,I know obd 2 tells you more just because it's the later system. Just guessing but I wonder if say a 1 system would tell you that you have an injector problem leaving it up to you diagnose which injector is at fault where I know obd 2 system would tell you say injector number 6 is causing trouble.
This might help tell you what the 1 system can do but remember some are not applicable to boats |
Nautique2001
The issue I'm having only happens maybe 3-4 time per Lake outing. It's something to do with idle speed and engaging into gear. Prior to engaging it into gear, the engine is idling a smooth and steady 680 RPM. Load on the engine will drop it to about 400 RPM, at which point it's still running but sounds like it may stall. I'll just click it back to neutral and the RPM's rev right back up like nothing happened. Feels like my old vapor lock days with my 1980 Nautique. Either a sensor is out of whack telling the engine more fuel please or there's something happening with fuel pressure in that moment. I was thinking fuel pressure regulator or throttle position sensor. I have zero issues with the engine starting, idling smoothly or acceleration to higher speeds. I was thinking if it were an injector issue, the problem would be consistent. Bottom line is I think she's starving for fuel under load when this happens. Hope to find that right replacement part that makes her happy again!
Ken |
Did not mean to imply that you had an injector problem just using it to illustrate a point on how the different obd systems work. Might want to do some searching on pre 95 Ford V8 FI systems used in Mustangs,Crown Vic's etc they used the same basic systems,you might find a way to test the TPS or the fuel pressure regulator
Orlando76
Intermittent Vacuum leak?
Nautique2001
Good point, I never thought to explore the auto industry and their issues. I think the 5.8 engine was in the Ford Lightning F150. Not a bad place to start.
What causes a vacuum leak? Is that a matter of tightening something or replacing a part? |
Nautique2001
Looking at a Ford truck forum with people who are complaining of hesitation on their 5.8 liter. One guy mentions a bad throttle position sensor. Also mentioned an O2 sensor. Do inboards have O2 sensors?
No o2 sensors on yours- don't overlook 5.0 forums either alot more of them in use and modified so there is alot of experience there compared to 5.8's. 1989-1993 Mustangs are the years closest to our boats
MrMcD
The spark plug in your picture looks like it has very few hours on it. It also looks like you are running lean. The should be just off white to light gray or light tan. Not brown/dark gray or black.
Lean burn conditions do run hot so your father is on track. Lean could be vacuum leak. If this plug only has 5 or less hours on it, you may just be seeing it is still new. Injected engines are leaner at idle than a carburetor for sure. |
Nautique2001
Thanks for all the feedback. Sounds like my Dad and I need to check the vacuum. Is there a gauge for that and is there anything vacuum wise we need to check? I know I'll probably end up bringing it to the Benjamin Correct Craft repair facility in CT. Or zip by Brad's at Lost Lake. It's so frustrating that I can't figure this stuff out!
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4231 |
Ken, I see in your diary that you brought it to MacCallum's a few times. Mark there is in my experience an extremely good mechanic.
I had the same problem when I first got my boat 6 years ago. I didn't figure it out, nor did Mark. It seemed to resolve itself to some extent as I ran the boat more. It's much more pronounced when I've been running for a long time, and less so during ski sessions when the boat runs for 10 minutes then is shut down for a bit as we switch. At it's worst it would almost stall, recover and surge a bit. It never does it in neutral, never does it unless the engine is very warm. I've found it to be a non-issue the last few years and don't really notice it much. |
lewy2001
Ken a code reader is a cheap investment if you plan on keeping the GT40. Intermittent problems like yours can be the most difficult to solve. The code reader, if it has a stored code (continuous) may point you in the right direction by identifying a sensor fault ECT, IAT, MAP, TPS etc. This is better than just changing parts.
Once you have ruled out the most common intermittent faults in the GT40 relays and LP fuel pump. The next most common intermittent problem with the GT40 is the PIP sensor inside the distributor. Over time the plastic housing encasing the hall effect sensor cracks allowing it to move. Open the dizzy and see if the housing moves with some firm to gentle hands only force. I still would not rule out a fuel supply problem. I left a fuel pressure gauge in line monitoring pressure for almost the full season one year trying to isolate a intermittent hot start problem. The only time you can trouble shoot a problem like this is when it is actually happening. |
peter1234
Grand Poobah Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
If your engine was Carburated i would be looking at ethanol problems or water in the fuel. Does Fuel injection suffer from the same stuff? off idle bucking ,hesitations and up and down rpms at an under load condition. quickly clearing up is a sure sign for normally aspirated engines
Nautique2001
It's fuel injection.
I'm definitely going to order a code reader. Pretty inexpensive investment to help chase the issue. Yes, MacCallum's Boathouse has had my boat twice. Tuned it up and gave it a clean bill of health. Mark said it's a strong running engine. I don't think it acted up for him when he Lake tested it. He checked the fuel pressure and vacuum and the tests came back fine. Will put a code reader on the engine and start from there. I can live with the issue but it is annoying. With any luck it will just stop. Thanks for all the suggestions, guys. Ken |
quinner
Ken, Do you have perfect pass?
Nautique2001
Hi Chris, yes I do have Perfect Pass Stargazer. This hesitation issue happened before I had Correct Craft install it. Ken
quinner
Kind of reaching but the servo can mess with your throttle a bit. My PP has a few quirks that drive me crazy. Anyways if issue occurs when PP is turned off then it is likely not PP related.
JoeinNY
I don't see a low pressure fuel pump on the list, IMHO it should have been the first thing replaced. Hack repair or not if it hasn't been replaced I would buy a new LPFP and put it in, drain the other one completely and blow some wd4o type stuff through it and then hold onto it for a spare. This part is relatively common and can be bought cheaply online and installed yourself for less than an hour labor at your local dealer... they fail often enough that a spare and experience in how to change them is a good idea.
Nautique2001
Hey Joe, good point. Thought that was kind of a part that either works or doesn't. Do you think I should try replacing this first or do you think I should order additional parts to replace all at once? On a scale of 1-10, what's the difficulty level replacing this? 10 being the most difficult, 1 being most of you all can replace it in your sleep or after 2 cases of beer. Ken
JoeinNY
Id give it a 3 cause its not located right up at eye level but its not difficult.. I would replace it and not anything else unless the problem shows back up this summer. It has all kinds of fun and exciting failure modes and not just dead in the water .
Nautique2001
Got it, thanks Joe. It's on my shopping list along with the testing device. I have heard those suckers can go bad and cause a world of hurt. Just need a little warm weather and we'll be good. Ken
tryathlete
LPP weakest link.
