Heater installation. Where to connect hoses |
weekendwally
Newbie Joined: May-04-2016 Location: Ktown Status: Offline Points: 3 |
Posted: June-25-2016 at 12:47pm |
I have a new to me 1987 SN. I found a new in box heater craft heater on craigslist. Now to instal it. Any advice on how to plumb in the heater? I found this http://www.skidim.com/Y-FITTING-1-X-5_8-PCM-Ford-Carb-or-EFI/productinfo/H423/ is that the best way? Where to take the water out and where to put it back on the block/pump? Want to get out on the water but the wife is fair weather boater only. Heater should help.
Thanks. |
Right behind the distributor,there is a plug in the intake manifold. That is where you you need to install a 90* fitting for one of the heater hoses to attach,that is where the hot water comes out of the engine. The Y on skidim goes into the water intake hose of the boat,mine is just before the raw water pump. Mine originally was connected to the U by the right below the circulation pump but at idle speeds you didn't get any heat. The Y gives you heat at all speeds
GottaSki
Yes, heaters are good for date nights
I had suspected that method put too much cool water in the engine at idle. Good to hear it works well I used a street elbow and barb onto the heater return port on the water pump. there should be a allen pipe plug there, aiming at the thermostat housing. Some grinding of the street elbow was required, but gets good flow at idle. Routed much like an old F250 is. Same outlet up top on the intake. |
River Rat to Mole |
weekendwally
Thanks guys. I had searched all over. And couldn't find this information anywhere. Not with enough description to go for it. Sounds like GottaSki`s method would be a bit cheaper. I am in Canada so Skidim gets more expensive.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4232 |
Mine is exactly like Gary's. I used the temp sensor port on top, so used a T so I could keep the sensor plumbed in that location and take the heater water out the top of the T. Once engine is warmed up I get plenty of heat at idle.
