1985 Ski Nautique voltage |
kgodfrey3398
Newbie Joined: January-29-2016 Location: Riverside, AL Status: Offline Points: 19 |
Posted: May-02-2016 at 6:22pm |
I am having an issue with my '85 ski Nautique. A few weeks ago, I ran her and the engine started skipping and would eventually bog down and quit. I thought it was the coil so I replaced it with a PCM Power Plus coil. I ran it today and it ran perfect with new coil for an hour then it started to skip again at high rpms, but the skip was not nearly as bad with the new coil. It has electronic ignition. I believe something is causing it to lose voltage when it gets hot. It could also be a bad alternator. Let me know if more information is needed.
Kirt,
The EI ignition, is it one of the conversions? They are known to be a problem. Is it factory or did someone convert it? If it was a conversion, is it designed to be run with or without the ballast resistor? Get the VOM (volt Ohm meter) out and get some good voltage readings before jumping in and throwing parts at it again. |
kgodfrey3398
It was converted to EI before I got it. The coil is made specifically for EI and does not need and external resistor. At what points do I need to test the voltage and what should the voltage be?
Kirt,
I suggest getting a reading to the coil and the feed to the module. If it's low follow it back to the ignition switch, get a reading there while wigging the key. Beyond that, to my knowledge there no way to actually test the EI module. |
