2002 SAN Winterization |
Adamjbarn
Newbie Joined: November-18-2015 Location: Indianapolis Status: Offline Points: 4 |
Posted: November-18-2015 at 1:20pm |
Does anyone have the diagram on the plug locations to drain water? Apparently i have been winterizing all wrong and have been getting lucky. Thanks!
quinner
Which motor do you have?
Any accessories like shower, heater, dripless packing, ballast, etc.? |
Adamjbarn
No accessories. 5.7 Excalibur. Hard ballast tanks.
quinner
For the tanks just be sure they are empty and then run the pump(s) in both directions several times to ensure no water is there.
Owners manual should have a diagram, if you don't have 1 check the reference section here or on planet Nautique. Excal will have a strainer to empty, 1 plug at the trans cooler, 1 plug at the J-Pipe, 1 plug in the block + 1 knock sensor in the block and 2 exh manifold plugs, I also pull my impeller since it's so easy to do. You may have a plug in the VDrive so be sure and check that with the diagram. Once all the water is drained I put everything back together and then suck-up some pink stuff for peace of mind, that is up to you as a drain only should be fine. What have you been doing that is wrong?? |
Adamjbarn
I have just never pulled the plugs. My buddy works at PCM and we have been talking about it as well.
quinner
Drain first for sure, it's pretty easy on the Excal. I use Teflon tape on all the plugs before re-installing, do not use any on the knock sensor though.
