Ski drives fast in gear |
trn448s
Newbie Joined: May-23-2010 Location: Lake Lotawana Status: Offline Points: 27 |
Posted: May-23-2015 at 11:28pm |
My idle is 500 rpms. Soon as I engage gear my boat produces a wake and runs about 800 rpms right out of gear. Just tapping throttle in gear produces a wake. Constantly getting yelled at in no wake zones. 87 ski nautique 351 carb motor. Flat bottom boat. I have adjusted carb and rebuilt trying to figure this out. After the threats and bad looks I just tell people it's an inboard deal with it. Thoughts other than telling people to piss off. Adjusted timing recently. It's spot on.
Toertel
Gold Member Joined: August-26-2013 Location: Atlanta Status: Offline Points: 775 |
Your throttle cable might be to tight and rev right when you'r in gear.
Neutral on min is about 700 and and in gear it goes down a bit and ou of O push the throttle firther do the revs go up |
1994 Sport Nautique
Orlando76
Sounds like cables are misadjusted like mentioned above. The transmission should go in gear without any increase or movement in the throttle cable.
With boat off: Detach the throttle cable at carb. Put the shifter in gear to the first detent ball. Then adjust the throttle cable to fit on the carb. |
DrCC
remove throttle cable at carb
put shifter at neutral, carb at idle adjust cable end to extend past idle re-connect test |
SNobsessed
Even with it idling 600 in gear, mine will kick up wake. I alternate f -n to keep the speed down. I have seen other ski boats get ticketed. The DNR guy doesn't care why your boat goes too fast!
Tom, I totally agree with Chris above and I'm sure there are thousands more that agree. Don't go screwing with the carb. There's nothing wrong with it. Are you new to boating? |
