89 nautique no power to dash panel |
Itsj0nathan
Newbie Joined: September-03-2013 Location: California Status: Offline Points: 23 |
Posted: April-19-2015 at 5:25am |
so im replacing the lower dash panel on my nautique. Had to cut the original panel indicator light wires and pigtail them back once the new panel was placed on. I hit the blower breaker and it worked fine same with the bilge. Once i hit the ignition it worked for a split second then everything went completely dead. Ive checked the wiring and it seems fine. Ive check the 50 in the back of the engine and it seems fine, unless u have to hit that red button down w a hammer. Even when i put the key in the ignition i have no power. Thoughts? Tips?
Jon,
I suggest you get the VOM out and check were you have lost the volts. Since you state you had the power for a split second, I suspect the wiring is not correct and a fuse is blown. Start at the 50 amp breaker and move forward. What indicated to you that the ignition did work for that split second? |
Itsj0nathan
The dash indicator light came on for a split second. Where are all of the fuses located?
Itsj0nathan
Could the ignition breaker have blown causing all power im the dash panel to go out?
Jon,
As mentioned,the VOM is what is needed to get some readings on voltage. If you don't have one, the less expensive ones are around $20. They come with instructions but are pretty basic and easy to use. You will also find one handy around the house and car/truck. |
Itsj0nathan
So it seems like ive gotten it to work. Prior to i didnt need a key in the run position for the panel lights to work. For whatever reason I stuck it in there gave it about 30seconds and power was back. One thing i did notice or from what i remember is if i turned the key into the run psotion my gas gauge would show me my fuel. Right now it doesnt move when i flip it to on... Since i havemt ran it in a while would that be the reason or is something not properly working?
spiralhelix
Senior Member Joined: August-06-2014 Location: IL/WI Status: Offline Points: 496 |
I posted a colorized and labled dash wiring diagram in the other thread. Just make sure everything is connected correctly. PM me if you need a larger version. Without the key and the ignition breaker switch "on", you should have power to the clock and the rest of your breaker switches. Dash lights should be tied into your nav light switch. The rest of the gauges should be tied to the key ignition switch on the purple side. As Pete mentioned above, you'll need a Volt-Ohm Meter to see what is going on. For the fuel gauge you will want to verify it is getting power and that you are getting resistance from the sender at the dash 33-240 ohms. I first ruled out my sender by checking the resistance at the sender first, then moved my way up testing at each connection.
Jon, You need to check your wiring. It sure sounds like it hasn't been wired correctly when you did the panel. We've recommended you get a VOM several times. Again, it's a handy tool. The 30 seconds is concerning. Do you have a friend who may be more familiar with electrics that could help? You don't want to burn anything up. Follow Colin's advice on the fuel gauge but again you will need a VOM especially for Ohming out the sender. Besides the hot to the gauge, the resistance at the sender, make sure the sender is grounded as well as the tank. |
Jon, Have you found the problem? |
