Prop gone to the bottom of the river, and back! |
Post Reply | Page 12> |
kapla
Posted: April-06-2015 at 8:34pm |
Nice winter easter weekend!
Birthday party of my Girlfriend [;-)] on the river house. heading back home and after cruising like 50th y gas the boat. About to plane I felt a little vibration, so back to idle, probably a water plant caught on the prop so I give reverse... nothing...revs but no movement... I put forward...same thing...so either the tranny or damper plate went bad or the prop is gone...so to the water I go...no prop... had a neighbor to tow me back to the house. called the insurance tow and they would not pick me up due to high tide and wind. So I had to stay there over night and called them today morning to tow me back to mainland. out in the marina I was able to see damage...prop went away with a piece of shift. ..my guess is material failure. I installed the prop the good way! I might add some pictures later as I'm posting from my phone... |
<a href="">1992 ski nautique
kapla
I posted some pictures on Facebook can someone link them here? Thanks!
kapla
For the insurance claim I might have to tell them I hit something...
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Sebs Missing Prop
lewy2001
Kapla Has Adam been near your boat at all
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2064 |
Looks like he is missing some shaft too!
Toertel
Gold Member Joined: August-26-2013 Location: Atlanta Status: Offline Points: 775 |
On FB it looks like the shaft broke ate the upper end of the lapping area.
If I can get closeups, I can have the metallurgist in the office do a quick and dirty review |
1994 Sport Nautique
kapla
Yes Jody prop went away with a piece of shaft. ..
kapla
I have a closer picture but is kinda out focus. ..
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1720 |
A friend of mine had the exact thing happen to him. However, he was on a small pond and floated to the side and walked home! Not nearly the adventure you had!
IAughtNaut
Grand Poobah Joined: August-22-2010 Location: TN Status: Offline Points: 2568 |
I looked at his diary post last week
IAughtNaut
sucks man, hope you have a good spare
jbear
it happens. lost mine a couple years ago on Norris. had to be towed home by the Monahans. boat on the trailer for the rest of vacation.
john |
"Loud pipes save lives"
DayTony
Gold Member Joined: June-30-2013 Location: Salem MA Status: Offline Points: 830 |
wow thats sucks, sorry to hear. time for a new shaft i would say!
It makes me wonder if maybe that wheel was stuck real good at one point and someone heated it too much when trying to remove it causing it to compromise the hardening. its a bummer when that stuff happens, always happens in the worst weather too. |
1988 Barefoot nautique-454
Hollywood
Looks plenty inside the lapped area. Nothing you can do about that!
DayTony
also looks like it hit the rudder a bit on its way out. wonder if that helped out at all with the broken shaft.
baitkiller
You don't see a rail ways every day anymore. It used to be more common, now its all big fork trucks.
I would imaging that you would be able to source a shaft locally, plenty of sailboats running 1" shafts that could be cut down if need be. let us know if you need any help. |
62 wood
Bummer.... What prop was on it?
kapla
Had a acme 1442,
I have a spare oem 14 X 16 and a spare shaft. I have to wait to the insurance liquidator to see the damage and then do the replacement. The shaft was locally made. Seems poor alloy as I have heard same thing happening to some local ski boats that run 1 1/8 shafts from the same supplier. May they are good for low hp applications. Now I will consider an are shaft or try another supplier. |
kapla
I had the shaft worked a couple of time due to hitting logs.
I never heated it to remove the prop, I have a real good prop remover. |
kapla
The marks on the rudder are pores or voids in the casting...it's also a locally made rudder...po repair
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3887 |
Kapla,
I understand the issues with importing, but it sure would be nice to get a double taper shaft for Discount Inboard Marine while this one is broken. Saw it at the coupler and install the new double taper shaft. Donald |
jbear
go double taper. got mine from CorrectCraft parts...Eddie put it on..no problem.
john |
kapla
Both my shaft are already double taper.
kapla
So seems im a lucky sob! My prop has been found by a friend of mine.
Water was very low today enough to make the search easier. I will have it with me on monday... The piece of shaft is attached to it! |
Seb,
Yup, that's a lucky find. I suggest you have the prop checked and balanced. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4231 |
Wow, can't believe you found it, a prop in a river is a needle in a haystack. That's some solid good luck, glad to hear!
kapla
Will do Pete!
Luchog
kapla
