fresh water clean out |
connorssons
Platinum Member Joined: January-17-2009 Location: Michigan Status: Offline Points: 1414 |
Posted: March-01-2015 at 11:08pm |
did Correct Craft put a fresh water clean out in the transom to flush the motor from the factory?
Yes, as an option. To my knowledge, they utilized the Perco Flushpro. Some have experienced breakage so I suggest the Tim Benjamin method. |
connorssons
Thx pete! There is one in the bfn im looking at. What was prone to breakage?
storm34
If I remember correctly Bret Hectus had issues with one on his Dom/BFN that caused cooling issues.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4231 |
Jeff, do you need the flush or just curious about it?
I just put the hose fittings that Pete referred to in my intake hose, just connect the hose and all set. Couldn't be easier and no way to pressurize an engine if you leave the hose on with engine off. |
connorssons
The bfn I just made a deal on has this option, have never heard of it. Just. Diggin and learnin! Lol so what was the issues this add on has?
Jeff,
The problems I've heard about are the plastic housing breaking and the spring loaded vale not closing properly. Someone mentioned that Perco made improvements so if you do have an issue with your existing, you could at least replace it with the newer version. |
