  New Posts New Posts RSS Feed - performance characteristics of vertical roller mil
onlysunny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote onlysunny Quote  Post ReplyReply Direct Link To This Post Topic: performance characteristics of vertical roller mil
    Posted: September-15-2014 at 12:31am
Vertical roller mill is a kind of high efficient energy saving equipment, which is a single large production capacity, energy consumption of unit product is low, narrow size distribution of the products, high purity, good fluidity, vertical mill is a kind of superfine grinding equipment, production and processing has been widely applied in foreign white non metallic minerals industry, the current domestic scale non metallic minerals also tend to use the equipment technical process to produce the product of TSP, barite, limestone and other non-metallic minerals, through cooperating with ultrafine classification equipment and processing equipment, to achieve product fine production.
Characteristics of vertical roller mill performance:
1, low operation cost:
(1) grinding efficiency is high, the power consumption of vertical mill grinding roller and the material bed compaction ground material, low energy consumption, milling system than the ball milling system to reduce 40-50%, and with the raw material moisture increase, energy saving effect is more obvious.
(2) the metal loss is small, with special materials, lining and roll grinding and long service life, reduce the operating cost, high utilization rate;
(3) equipped with external circulation device, capable of reducing the power consumption further;
(4) large feeding size, up to the grinding roller diameter of about 5%, typically 40~100 mm, so large and medium-sized vertical mill can save two stage crushing.
2, low construction cost:
(1) the vertical mill has the advantages of simple process flow, and the milling system compared to the area can be reduced by about 50%, the construction cost is reduced by about 70%, a building area of small, less space occupation.
(2) mill crushing, drying, grinding, grading conveying into a whole, simple, compact layout. Can open layout, the construction cost.
3, easy and reliable operation:
(1) is equipped with an automatic control device, can realize remote control, simple operation and easy.
(2) because of the roller and the grinding disc lining device to prevent direct contact plate quality inspection, and avoid the fragmentation of the violent vibration.
4, the drying ability strong, vertical mill using the gas conveying material, can control the air temperature in the grinding of the larger water material, make the products reach the final moisture content, on the vertical drying up to 12~15% of material grinding, even drying and milling, drying of the material is only for 3~4%.
5, the product quality is stable, uniform particle size distribution. The short residence time of material in the mill, easy to detect and control the product size and chemical composition, stable product quality.
6, easy to repair, maintenance, flip through oil boom, roll sleeve, liner replacement can be in a very short period of time.
7, environmental protection, energy saving; small vibration, low noise, little dust, clean operation environment, adapt to the demands of environmental protection.
