Trailer Repair |
DMH
Senior Member Joined: July-25-2014 Location: Milwaukee Status: Offline Points: 134 |
Posted: September-05-2014 at 2:22am |
Greetings Ya'll,
I've been busy boating as much as possible. Now it's time to start working. I am embarking on a few trailer projects. - I am missing the two pieces of wood that stop the nose of the boat on the trailer, perhaps called bumpers? It looks like it maybe a carpeted 18" 1 x 12. Could someone please measure theirs and provide the dimension? - Also you'll notice that the front eye has a rachet strap connected to it. I have looked at turnbuckles however the weight rating seems to be very low compared to the weight of the boat. Nor do I know how I woud connect this to the trailer. Turn Buckles - Lastly, I'm currently tying the stern down over the top of the boat just in front of the back seat. My strap is weak and I'm concerned that if a use a ratchet strap I may damage the corners on the top of the boat. Any ideas on the correct way to tie this down? Suggestions & comments appreciated. Thank you |
Hollywood
Thanks(1)
You can pretty much use whatever you feel comfortable with. Someone will measure their bow stop boards eventually. The turnbuckle doesn't have to be "rated" for the weight of the entire boat, but I can measure mine too. Use whatever strap you want in the back.
audiodude
Senior Member Joined: November-19-2012 Location: Badin Lake Status: Offline Points: 299 |
Is there really a need for the stern strap. I don't use one, haven't had any issues. Should I be using a strap?
1989 Correct Craft 2001
In the words of Milton Berle: "You can lead a man to Congress but you can't make him think" |
Some states require a stern strap... The only time you really "need" one is if you're in an accident. The boat isn't moving under normal driving conditions- I've towed half way across the country many times without straps. The few times I've used one, I put a rag or towel between the strap and gunnel.
Zach could tell you the dimensions of the crash pads or even sell you some modern Ramlin plastic replacements that will take abuse a little better than the carpeted wood originals. Like HW said, the turnbuckle doesn't need to be rated for a dynamic load or the static load of the weight of the boat... Unless you plan to hang the boat with it of course. If you're just holding the nose down/forward like cc intended, a lower rated turnbuckle (like original) works great. |
SNobsessed
Thanks(1)
Here are some photos I hope will be useful.
My bow stop pads are 10 X 18 inch. I welded on a little cross bar spanning the skid plates of the prop guard. Now i just strap down from the platform brackets. It is much easier than the gunnel strap I used to use. |
AAM196
Gold Member Joined: October-23-2012 Location: Pittsburgh, PA Status: Offline Points: 846 |
Thanks(1)
for the stern... you could use a ratchet strap from your swim platform bracket to trailer... just don't forget it's on there at the ramp
If I am traveling with a cover on tied to trailer, I rarely bother with the stern straps... don't ratchet too tight if you are going over top so you don't damage gel/fiberglass. |
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
Thanks(1)
Here is how I strap the Stern down on my 88'. Not quite the extint of Chris but works none the less....I too use the platform brackets but just use a short strap to ratchet it down to the trailer bunks.
Been there done that...works good too as the boat wouldn't back off the trailer AND actually floated the trailer over the ramp lane curb! Doh!!! |
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 758 |
I talked to the guys at macs tie downs about this issue and they say you need double the working weight load for the strap so essential one over 5000lb rated and when you ratchet it down have atleast 2 wraps on the rachet for solid load capacity
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
DMH
Hello All,
Thanks for your input on this project. A friend and I finally had a chance to put in place the new bunk carpet & bow stops. Still working on the front tie down and having new guides welded. Here a few shots for you. Again, thanks for your suggestions. |
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
Now redo the lights...led maybe...at least have them match...cut off the excess threads on the bow stops...get a couple rattle cans and spray that thang
This is the life
GlassSeeker
Maybe somebody can help you with a guide pole too
This is the life
DMH
I do have a welder friend who will help with the guide poles. They bolt on so I'm expecting the project to be straight forward.
Regarding the rust. It's not in budget to sand blast. As mentined maybe spay paint to hold the integrity. I prob should at least try to remove a bit of the rust with steel wool or something before I spray the trailor. Any other thoughts on that? |
RobertV
Groupie Joined: September-17-2013 Location: Yorktown, NY Status: Offline Points: 84 |
I would suggest using a wire wheel with a drill for the rust. The wire wheels come in many different shapes and stiffness to suit your needs. If you plan to paint the whole trailer with spray cans then invest in a plastic spray grip/trigger that mounts on the can = your index finger will thank you.
Dreaming
+ 1 for a wire wheel on the rust. I used a grinder and harbor freight wheels to strip an old bronco last year. it goes pretty quick and leaves a decent finish. make sure you have a face shield and wear long sleeves and gloves.... the wire wheels come apart as they catch on stuff, and you'll find the little wires in your skin and clothes.
JPASS
I've used Ospho on rusted metal before with great results.
'92 Correctcraft Ski Nautique
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Hammer tacker staple are not always galvanized. They may rust. I use Narrow crown staples on my bunks as they are.
I use my rear lift ring for my tie down straps. |
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
