Putting Antifreeze in engine mount holes |
Swansonhomesllc
Newbie Joined: August-16-2014 Location: Eau Claire, WI Status: Offline Points: 24 |
Posted: August-24-2014 at 2:29pm |
I know this is a very touchy subject but wondering on peoples thoughts on putting antifreeze in engine mount holes prior to CPES? After lots of research I have concluded this is a good solution to get some more time before stringers need to be replaced. My method. Antifreeze in holes to soak into wood and act as a bonding agent for the CPES. CPES in holes next. Fill remainder with laminating resin. Drill new holes and replace bolts.
The boat appears to have weep holes on stringers in exhaust bay. (you can see them in pic) I am assuming the antifreeze/CPES would wick out those weep holes? Can they be blocked off? Are they really needed? Everyone's comments positive and negative are appreciated!!!! |
SNobsessed
I would say that antifeeze would be an anti-bonding agent.
A much better approach (without full tearout) would be to take a spade bit & oversize the hole, pulling out as much wood as you can. If you don't get to good wood, stop & prepare to replace the entire stringer. If you do get to good wood, you might try soaking the hole with acetone (dries out wood) then filling the hole with epoxy resin + chopped or milled fiberglass. PS, mark your spade bit with some tape so you don't get carried away & drill thru the hull. Laugh but others have done it! |
Cpes already has it's own "bonding" agent from what it's made of. Antifreeze always feels oily to me and never drys completely if you spill some. Don't over think this,if it's rotten it's too late anyway, by the looks of them,they look fine -use it and have fun.
As the others, I feel the antifreeze is a bad idea.
Hollywood
Where did you get this antifreeze idea?
DrCC
And, did your research include and explain the 3 different types of glycol?
Swansonhomesllc
There are lots of articles on the internet supporting the use of antifreeze (ethylene glycol) on wood rot. The attached link is one that is worth reading. http://www.acbs-bslol.com/Gadgets/D97WoodRot.htm
Obviously it is always better to replace the wood but if you can gain a few years from a repair it is certainly worth it. I do know that people mist antifreeze on open wood areas annually as preventative maintenance. |
audiodude
Senior Member Joined: November-19-2012 Location: Badin Lake Status: Offline Points: 299 |
I once read an article which said that fungus is the main cause of wood rot and that Anti freeze or sodium borate were good treatments to prevent fungus
1989 Correct Craft 2001
In the words of Milton Berle: "You can lead a man to Congress but you can't make him think" |
Mojo
Grand Poobah Joined: December-06-2006 Location: United States Status: Offline Points: 3104 |
Is it me or does the stringer in the picture look pretty darn good? Where do you see rot? You mentioned that the bolt tightens pretty good, so why do you feel the need to mess with it??
05' SV211 TE
Swansonhomesllc
The glass looks good......the wood under it is rotten. The 4 in the rear you can pull out with your fingers.
Air206
Joel-
Contact TimD. Tim has used a pour-able replacement wood method that is used on off-shore boat transom repair. If you are trying to salvage the mount and gain some time..... it would be worth consideration. I don't really know the product name or its immediate limitations, but it is worth looking into for this limited application. |
Sea cast is what I think your thinking of Steve
peter1234
Grand Poobah Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
why wouldnt you over drill it then cpes then an epoxy resin .Then drill for the bolts til you do the stringers. that cpes will penetrate quite a bit stop over thinking it
DrCC
Swans link to Bob's Land'O'Lakes Chapter
Add this to your research I don't believe that Bob Speltz is talking about using this inside encapsulated fiberglass. And, It sounds to me like Bob may be one of the "confused" as described in the other link. |
Air206
Thanks Gary.... Tim has done some cool repairs with it several years ago. He can tell you about pros and cons.
chubbytug
Newbie Joined: October-20-2013 Location: ohio Status: Offline Points: 6 |
I used the Sea Cast product to repair/replace stringers in a 1990 wellcraft with a 390Hp Big block and it worked very well. I cut just the tops off and removed all of the old wood. Poured in the Sea Cast using the sides as a mold, and then capped off with new Fiberglass. The only downside was the cost as the Sea Cast was rather pricey.
Air206
That is my understanding of its use.... the fiberglass at the engine mounts can be left to maintain engine support, rot dug out, and Sea Cast poured in/around..... its like liquid Coosa! (that would explain the cost)
Interesting concept............. |
peter1234
does the sea cast give the same rigidity that fir stringers would though? i understand the fiberglass tied to the hull lends some but doesnt the boat flex with wet rotten stringers? seem that the lack of the firs strength would lend to flexing and sea cast and gel cracking . i was always under the assumption that it was for rotten transoms only
dangerwil
Senior Member Joined: June-20-2013 Location: Orange Park, FL Status: Offline Points: 319 |
Seacast makes amazing stringers. This guy did a excellent job on an old Arkansas Traveller.
Seacast stringers YouTube |
peter1234
amazing is amazing looking? but what i am asking is what is the strength comparison compared to wood . it seems to me that there is a flex and rebound to these hulls with wood stringers , does seacast crack when moved like a bow ( as in bow and arrow) or is the movement negligable
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21104 |
Coosa is made of sheet fiberglass and foam and is stronger an lighter than wood... it doesn't have an equivalent pourable counterpart that I am aware of. I have no experience with seacast but believe it to be pretty expensive and heavy. Whether it is a good choice for such a repair is probably debatable.
Cpes down the holes followed by epoxy resin thickened with a high strength filler would be my method of choice in this case. Cc hulls are thick and small and dont really flex like larger, thinner boats do. I would not (and have not) worried about (re)building a boat "too stiff". Doug fir was sold as a dampening, flexing stringer material and that is probably true, but hollow fiberglass stringers seem to do just fine in Malibus. Cc used a healthy glass schedule over the wood from the 70's forward and I've seen a few boats whose stringers turned to mush and the only strength left was in the overlying glass... And they weren't about to fall apart. Now that the stringers are filled with foam, they seem to be just fine as well. |
Swansonhomesllc
I agree with TRB about strength of hollow stringers. My guess is nearly CC boat prior to 93 has rot and will continue to get worse. How many do you actually hear about failing and sinking? I just don't want the engine and trans twisting due to loose lag bolts. Once they are tight again I'll run that mustang for another 5+ years. Will probably be more solid than it's been in 20 years.
Orlando76
I know somebody who uses sea cast for stringers and transoms. I understand Sea cast to be strong, more impact resistant and as far as the flexing.... I don't know if it flexes but even the manufacturer recommends it for stringers and like Tim says, these boats don't flex too much. It's screw retention seems to be like Coosa. At 202$ per 5 gallons seems to be inline with prices as far as I understand.
Air206
Tim- I was using the "Coosa" analogy as a metaphor...... a "pourable" structural synthetic. While not an engineer, I understand it it not the same. It is reported to not be heavier than the dry wood it is replacing. True, It is expensive - esp. in comparison to antifreeze, and epoxy..... I thought we were discussing options. Sea Cast is a product sold to accomplish the replacement of marine structural wood...... I haven't used it - so I can't praise or bash it. I rec'd the OP contact Tim D for handing and use opinions. |
Understood Steve... But there are a whole lot of composites available out there, of which Coosa and seacast are 2 specific brands/products and they appear to have very different composition and properties. Probably best to use the generic term (composite) so as not to confuse the issue.
It has been documented that the hull starts to show gel cracking where normally it does not occur. When found most seem to stop using before they fall apart |
Air206
10-4..... |
I thought someone here was going cut the tops off their stringers remove the rotten wood and refill with seacast. I believe Pete told them not to do it,don't remember if they ever went thru with it. Or maybe they did and went down with the ship-----
SNobsessed
To me, it seems like digging out the wood within 2 walls would be as much work as slicing the glass at the floor & prying the stringer out. Sure you have to re glass, but then you know you have good adhesion.
Maybe peolple are talking about only doing only a small section, in which case 'sistering' would be an alternative. |
