Transmission Rebuild Dirty Neutral-Should I Care? |
dwouncmd
Gold Member Joined: July-10-2009 Location: NC Status: Offline Points: 919 |
Posted: September-06-2013 at 8:53am |
After replacing the shaft and having FFM rebuild the 1.23 transmission for my 89 SN, I noticed a dirty neutral while adjusting the packing gland with the boat in the water and the motor idling, 1 turn per second. Interestingly, when I ran the boat in the driveway immediately after the rebuild, before the first lake test, the prop shaft did not move; then again, the cutlass bearing was new and had never been wet, there was no water coming through the packing gland, and I think the packing gland was too tight.
I have seen replies on other threads stating a dirty neutral is caused by clutch plates dragging. I think the warranty period for the rebuild is a year, but there are just a few hours on the rebuild since I just got it back in the boat. Is this a reason to send it back? |
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7 |
SNobsessed
I would call FFM to discuss it.
Let us know what you find out. Maybe it is the nature of the beast. Mine has had a dirty neutral since I bought it 6 years ago. |
vondy
Platinum Member Joined: November-29-2007 Location: Dallas, Texas Status: Offline Points: 1116 |
Same here after Eric rebuilt mine. It's nothing like it was before the rebuild, you can stop the shaft spinning with a light touch to the shaft coupler. Before the rebuild there was no way to stop it short of wedging a piece of wood at the prop. I would actually unhook the shaft from the coupler when winterizing or running on the trailer to keep the cutlass bearing from burning up.
Eric said it was normal for a little movement after a rebuild on the velvet drive. |
phatsat67
I would imagine all of the pieces need a little time to wear in to each other when they are installed at the correct tolerances.
Not sure never drove a fresh rebuild. |
Bones71
Senior Member Joined: March-09-2013 Location: Bettendorf Ia Status: Offline Points: 334 |
I was told of a good shop near Chicago called " federal marine transmission inc" I was told they do good work. That is a good question to ask. I would think moving in neutral would be wrong on a new rebuild but I know nothing. I will be sure to ask. I plan on sending mine in soon.
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
dwouncmd
Thanks for the insight everyone. I may give FFM a call, but I don't think I will worry about it anymore.
89 SN
SanderB
Newbie Joined: February-19-2015 Location: The Netherlands Status: Offline Points: 1 |
Did you manage to get some more info about this dirty neutral?
My '91 PCM 40a 1:23 has just been rebuilt and also has a dirty neutral. You can stop the spinning shaft by hand, but it's enough to get the boat moving at about 2-3mph while in neutral. My mechanic says it's normal, but in my opinion it's very annoying to have a boat that tends to go forward all the time. |
Sander,
Welcome to CCfan. Have you been on site before under a different screen name? The dirty neutral is not normal. It sounds like your "mechanic" is covering up a "rebuild"! What does he consider a rebuild? |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3391 |
Welkom bij het leukste botenforum Sander
Welcome to CCFan Sander. If you ever want to talk boats, come on down to Belgium (Maaseik, near Weert). Beer is always cold in the fridge for CCFaners Pete is one of our mechanical guru's here. And if your mechanic really rebuilt your trans, as Pete stated, it should not have a dirty neutral. My old trans has a little dirty neutral and I got used to it. Works perfectly fine for the rest. And when in neutral, the prop makes one spin every two to three seconds, so not to bad yet... |
