  New Posts New Posts RSS Feed - Oil pump rod twisted
Miss-B-Haven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Miss-B-Haven Quote  Post ReplyReply Direct Link To This Post Topic: Oil pump rod twisted
    Posted: May-21-2013 at 8:27pm
Alright guys I pulled the motor from the boat to better the oil changing situation with a drain hose off the pan plug so that the oil didn't get drained in the hull anymore, and since the motor was outI decided to go through it. Good thing! The hex oil pump rod is twisted in the bottom of the distributor, and bound in there. I am not going to put that dist. back in, and am wondering if there is a step up in a different points dist., or what others have gone to? Thank you in advance for the replies. B
KEEP'N THE "KOOL" IN OLD SKOOL
Nautiquehunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2013 at 3:39pm
Better check the oil pump , pick up screen and valve seals . Something caused the pump to get tight or momentary lock up then the oil drive will twist and break. I have seen the valve seals get rock hard and break up then get sucked up in the pump. The timing gears can also cause this.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2013 at 4:51pm
Mike is right, what it absolutely was not was a problem with the distributor (although it might have broken the distributor gear). The crank turns the cam, the cam gear turns the distributor, and the only way for that shaft to twist is for the oil pump to not be able to turn when the distributor turns. Whether from debris, or excessive wear/pump breakage.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
cadunkle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cadunkle Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2013 at 4:59pm
Or high volume pump without hardened shaft, or even with a hardened shaft I've seen 'em twist a few times particularly with heavier oil. High RPM, heavy oil (20w50), and high volume pumps are the contributors here. Or, outright breakage of the pump or debris (unlikely to get past screen) as you mentioned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2013 at 7:46pm
Cory,
Why the high volume pump?
