Coupler - Velvet Drive to Shaft - '77 Nautique |
t317
Newbie Joined: June-08-2012 Location: Rockford Status: Offline Points: 5 |
Posted: June-08-2012 at 3:22pm |
We were fixing the leaks in the exhaust hoses and patching the holes in the fiber glass "mufflers (tubes)" and pulled one of the plugs out of the coupler from the Velvet Drive to the propeller shaft. It was dry and had some rust in there. We are not sure if it needs grease or something inside.
I have attached a picture. This is on a '77 Ski Nautique. Thanks. T. [IMG]uploads/12606/Coupler_Question.jpg |
t317
Picture did not work. Trying again.
T. |
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
Tad,
Welcome to the site. I have never seen a coupler like that. Curious to hear what the others have to say? |
83Ski
That is the oddest coupling half I've ever seen. Maybe Eric will recognize it. To me, it looks homemade when someone didn't know the coupling is supposed to be a heat shrink fit, had problems with the original and added the rather large bolts to try to hold the shaft in place. The other option is it may be someones idea of a self aligning flex coupling installed by a PO when he couldn't get the alignment correct???
Tad, Welcome to CCfan. Please tell us more about the boat. |
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1410 |
I think its one of these,don't think you need to add grease check the rubbers bushes on the four bolts.
Federal coupler |
Lets have a go
Roger,
You sure "nailed" it. Thanks. |
t317
Perfect. Seeing that makes me feel that we are ok with what we have.
You asked for information on the boat. I purchased in 1997 for $5,000 from someone whose wife was making him sell it so they could buy an entertainment center. I never could understand selling a boat not to upgrade but to buy furniture??? I think I would have traded in the wife.... He had the boat for quite a few years up near Janesville at a summer house on the river. Before him I do not know. I thought I heard something about a ski team, but I doubt it as the boat does not look that beat up. Probably just owned by someone on a ski team. It has sat for the last 5 years as I upgraded boats. My oldest son now wants his own boat so I brought it out of storage and we are putting a tower on it. Leave it to a kid to not understand it is a SKI boat. Attached are some pictures of us putting a tower on the boat. The boat will be on the river in the Rockford area this summer. Thanks. T. |
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
Odd coupler and a black framed windshield on a 77
Brian
The boat looks like it's in pretty good shape. I hate to see the tower on it though!
Eric (our resident trans expert and rebuilder) will be along soon and I have a hunch he's going to "poo poo" that coupling half. I'd be inclined to get it off and go stock too. Have you checked the alignment? Of course with the flex in that coupling, it's going to be hard. Brian, It's a 77 so the black windshield frame is original. |
hotboat
oops must have been 76 and earlier silver that is a nice looking ride
Brian
its a Federal coupling, yank it and buy a split type, federals are for mis alignment, the used car salesman that sells them will tell you they are great, ive never in my life said to someone we better put a Federal on there because what you are trying to obtain is perfect alignment without it, its not needed if everything is correct....just a Band aid
Tad,
Eric's response was as I predicted. So, any opinions on what you want to do? I'd say that coupling went on for a reason. Even though the outside of the boat looks fantastic, how are the stringers? If in bad shape, then that may be the reason for the flex coupling? Have you done any checking? |
i think those federals run in the 400.00 dollar range to
WOW!!! A set of feeler gauges sure aren't 400! |
t317
The fiberglass on the driver's side stringer in the back was cracked away from the wood. The wood itself feels good when you poke it with at knife (we could only reach the top wood). So we poured a bunch of West System epoxy down the crack, which was pretty much the length of the back portion of the stringer, screwed the fiberglass back to the the wood and fiberglassed cloth on top of the crack to seal it.
I have not idea how to check alignment and what I should be doing about coupling, is there anywhere someone wrote about it? I would guess that coupling has been in there over 20 years. The guy I bought it from was not mechanical at all. Thanks for your help! T. |
Tad,
Take a look at this video to get an idea of what alignment is about. If you already found a bad spot on the stringer glass, understand you the boat is "living on borrowed time". Whoever told you about pouring the west down the crack, did he also mention problems most likely go deeper? There are plenty of threads here on CCfan that tell all about stringers and rot. Are there any soft spots in the floor? Is the floor still attached fore to aft to the hull sides? Have you tried tapping the glass with a light hammer wherever you can and listen for sounds of delamination? The coupling does need attending to. I'd go with Eric's recommendation and put a split coupling on the prop shaft. He likes them. The alternate is a shaft coupling system made by ARE. Once to get the coupling swapped out, then the alignment can be checked. We sure would hate to see you blow the trans and end up sending it to Eric for a rebuild. |
