Switch to elec ignition
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=4495
Printed Date: June-11-2024 at 8:48pm
Topic: Switch to elec ignition
Posted By: David Adams
Subject: Switch to elec ignition
Date Posted: August-13-2006 at 6:59pm
Should I replace the whole distributor or use the conversion kit such as available on Ski-Dim? Anybody here done the conversion themselves?
------------- 1974 Mustang
Posted By: michigan dave
Date Posted: August-13-2006 at 7:14pm
I have done a few of those conversions, the directions are pretty good. The only reason to replace the whole dist. is if its got lots of hours on it and the bushings are shot. The rotor should have very little side to side play. should be clean and without corrosion. Then I would certainly re-use the dist. (but hay im just a newbie )
------------- 1984 Fish Nautique
351ci- 14x13 four blade acme
south haven mi.
Posted By: boat dr
Date Posted: August-13-2006 at 8:31pm
slack in the shaft not really a factor w/conversion,min. side to side movement is ok. no slack or movement is allowed w/ breaker points due to dwell and timing concerns.put the mallory module and the power filter. this stops a voltage spike from smoking the module. mallory also recomends their coil #MAA-29216.filter #MAA-29351 ,i think the output voltage is considerabley higher,had to replace my new Accel 8mm wires because of leakage,bought a set of Taylor 9mm no more light show or Gottcha's . instant start and a 400rpm idle,simple but cost effective upgrade..........boat dr
------------- boat dr
Posted By: Tim D
Date Posted: August-13-2006 at 9:12pm
I replaced mine about 8 years ago, it was the best $90 ever spent. Better starts, and more responsive throttle. Keep your distributor if there are no issues in wear and timing advance.
------------- Tim D
Posted By: 79nautique
Date Posted: August-13-2006 at 9:18pm
conversion kits are all right but are not that accurate or consitant cyl to cyl as far as timing is concerned. Worn bushings will not increase or decrease rotor movement as it turns it will effect the the gap between the terminal post and rotor as the shaft no longer spins comcentricly but not a enough to really make a difference.
the main reason to go to a new dist over a point dist is the accuracy and consistantancy in firing cyl to cyl. Making it easier to adjust the carb for easy starts and better overall performance and then matching it to a high output coil improves fuel ecconomy and improve performance even more.
Posted By: mjg100
Date Posted: August-13-2006 at 9:26pm
I also installed one from Ski-Dim many years ago on my 84 2001. My boat starts and runs great. I would rank this right up there with the PSS shaft seal.
Date Posted: August-13-2006 at 9:30pm
there better than the points but not a new electronic Dist.
Date Posted: August-13-2006 at 9:33pm
thank you all very much!!!
Posted By: grim
Date Posted: August-15-2006 at 3:08pm
I have a 1978 wth a 351 commandor.
The distributer is broke, shouldi replace with a electronic from mallory? or the original?
------------- greatings from holland
Posted By: boat dr
Date Posted: August-15-2006 at 3:20pm
sumitt has a new Mallory .........MAA-YLM554CV cost 239.00 dont know if you need power filter or not w/new unit. OEM dist. will cost a least that for points ign. dont take a bussiness degree for that mod...boat dr
Date Posted: August-15-2006 at 3:37pm
I believe you want to use a YLM-554-DV for a reverse rotation engine or the optical version YLU-554-DV, the CV version is a standard rotation model.
Posted By: KENO
Date Posted: August-15-2006 at 3:54pm
Hey 79
I see you've changed your way of thinking.
Now you say a DV is for a reverse rotating engine. I do believe you got it right.
You've flip flopped on this over the years but I say you're right this time. I think you spelled everything right too. Good job
Posted By: boat dr
Date Posted: August-15-2006 at 4:03pm
sumitt does not stock that rev. rotation dist. very easy job to r&r old gear,boat dr. would not use the optical pickup,reason???????older motors deal w/blow by,a little oil film on said optical pick up renders it blind...not so w/magnetic,have installed many in clients I/O and inboard applications no problems..........boat dr
Posted By: grim
Date Posted: August-15-2006 at 4:04pm
The people at mallory told me part number Model Number: 9-26302
could that be right?
Posted By: The Boat - 80
Date Posted: August-15-2006 at 4:17pm
Good to see more posts on this question...I was a little shy in asking another question but I'll jump in again...
Our starts on the 80SN are inconsistent and sometimes we'll get nothing at all. The 351 engine is stock, nothing changed, just a rebuilt Holley carb. After reading a few posts on ingintion systems, it seems we'll benefit by switching to eletronic. I've read there is improved performance in completely switching vs. using a conversion kit...
My question is, what would be the price difference in doing each one correctly and completely...and how noticeable will the performance be? That will help me justify which path to take.
Date Posted: August-15-2006 at 4:20pm
they swithed to a new numbering system so if you gave them the DV version then it should be right.
Keno I went back and checked my old post instead of going to the catolog this time.
Boat dr.... your all wet on this one... blow-by will not effect the distributor in anyway shape or form and will not increase the amount of oil going up the shaft of the distributor. But then again you wouldn't want to spend the extra money to have a superior ignition system. That provides faster triggering, consistant accurate firing cylinder to cylinder and has fewer parts to go bad or break. The weakest link in a magnetic trigger dist are the two wires going to the coil that energizes the pole piece. Because the mechanical advance is always moving the base plate back and forth it causing the leads to work harden where they meet the coil windings and eventually they will break. An optical pick-up doesn't have the coil or wires to break or go bad.
Date Posted: August-15-2006 at 4:26pm
scott your looking at about twice the price for a magnetic pick-up dist vs a conversion kit and about three times the price for an optical version that I run, The HEI unit that is iavailable is about 3.5 times more once you buy the gear but your getting a new coil as well.
Posted By: boat dr
Date Posted: August-15-2006 at 5:11pm
79 you could be rite,omc tried the optical system for their outboards,cost them a lot of powerheads due to misfires and other related ignition problems. as far as blowby ,optical works on a light and a pickup the window tells itwhen to fire.no window no fire,oil film on pickup tells the sensor its not time to fire,omc had this problem,from blowby at the upper crankshaft seal. magnetic pickup,tho not as accurate nor as expensive will work just fine. 79nautique remember we are replacing a points type ign. in my way of thinking that is old tech. vs. new tech. donyt you agree?????? and the points work just fine for the rpm limits that we choose to live within.........btw what system are you running in you motor,will send you pics of my boat and how i spend my money,its called cost effective high performance.331 stroker 400 FT.lbs and 350 HP,wanna see what dist. i use,stock Mallory w/conversion kit. it alows me to buy thigs that make serious HP. gt 40 HEADS,Edelbrock,Holley and a brand new 331 stroker built by Houston Performance,also cam designed for this motor and application by Cam Research inc.plus new OJ 4 blade,wah buddy i aint cheap i just spend my money wisely.........boat dr
Posted By: KENO
Date Posted: August-15-2006 at 5:43pm
This is for grim over there in the netherlands.
If you have the old distributor in your hands look at the teeth on the gear.
If they go this way/////, it's a LH engine.
If they go this way\\\\\, it's a RH engine.
Whatever you decide to get, make sure you get the right rotation or you'll be screwing with swapping gears.
Try Discount Inboard Marine (they advertise on this site) and they'll get it right for you if you give them the correct rotation.
keno
Date Posted: August-15-2006 at 5:47pm
I use a mallory YLU-554-DV unit in a 351W and have just as much torque as your's and run 51-52 GPS with D8OE stock heads, mallory high output marine coil and a comp cams cam, balanced motor, re-jetted 4160 holley sinlge pump, edlebrock performer intake turning a acme 470 three blade prop.
Now I do have a set of heads being working on that I'm going to install later with new edlebrock polished alunimum exhaust manifolds. That is once the D0OE heads get the 1.90/1.60 farrera valves with .600" lift springs and scorpion full roller rocker arms on screw in studs with guide plates. Are machined and are ported to match the intake and exhaust manifolds then polished to let the new high lift cam breath at 6K.
But you really should stick with the larger combustion chambers that the gt40's have, you really don't need the extra compression or a high lift cam in your 302 stroked block.
Posted By: KENO
Date Posted: August-15-2006 at 5:58pm
Wow
Tim "the tool man" Taylor would love this gearhead talk.
I know I do.
And to make it even better, there's no slandering going on.
Keep it up, talk engines, post some pictures, this is great.
It's what this board is for.
keno
Date Posted: August-15-2006 at 6:12pm
I've posted pictures of my motor before no one wants to see it again
Posted By: boat dr
Date Posted: August-15-2006 at 6:29pm
79 my old 64 amer. skier, does not have the weight problem you do, ha ha, almost same set up as you but w/OJ 13x13 double cup @5000 i am running 52 gps mph @ dont use the fuel you do. remember be good to the environment,less is better. oh by the way the only reason i dont have a351 in my tub is due the engine cover,302 is all i can shoehorn in there,rubs the exaust now,tight fit,i pull a 24' parasail old school meets new school,gotta love these boats OLD OR NEW........ boat dr ps where are you located?????? am in La.
Date Posted: August-15-2006 at 7:33pm
I'm in St. Pete boat's in Indiana.
Posted By: boat dr
Date Posted: August-15-2006 at 8:43pm
how do you do such a long distance love affair????????????? i'm in monterey La,boat is asleep in her house in the back yard. sure do love these old boats. boat dr
Date Posted: August-15-2006 at 9:12pm
there no place to store the boat at the condo so I had to leave it in Indiana, I'llbring it down later. I do miss walking out the back door and getting in the boat and taking it for a cruise with some coldies.
Posted By: scott8370
Date Posted: August-15-2006 at 9:35pm
Chris
Hey when you get a chance,I'd like to see a good picture of your engine. When I Look through the For Sale section, I always make a stop at your boat. Thanks Scott
------------- Scott
Posted By: dchris17
Date Posted: August-15-2006 at 9:36pm
Hey 79 Nautique, when you come back to Indiana to pick up your boat maybe you could drop by and check out the SS Mini - I'm in Noblesville, north of Indy.
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=917" rel="nofollow - My 1974 Mustang 17
http://www.trooptrack.com" rel="nofollow -
TroopTrack : The Best Scouting Software
Posted By: boat dr
Date Posted: August-15-2006 at 9:41pm
love fla as much as La. was in Key West last month,had plans to ferry a 36' macgreger catamaran from Ft. Walton to Placentia in Belize. oncce in a life time trip for this old sailor.Alberto kinda messed all that up,weather delays, dodging squalls to 3 to 5 knot winds made for a long passage,610 miles in 4 1/2 days no bad for a blow boat. bailed in Key West after another storm was brewing south of Cuba. had to get back to the shop,envey you being there.lotsa boats both sail and power,would love to make the St. Pete boat show,better yet Stictly Sail,i have a dual addition...........boat dr
Posted By: grim
Date Posted: August-16-2006 at 5:11pm
Billy,
I spoke to correct craft in 1978 they produced left and right hand engines.
I dont know what my engine is. Can you have a look at my pictures?
http://www.westerengh.com/ski/tag.html
I think i have a right hand?
So i have to buy a right hand distributor
Posted By: grim
Date Posted: August-16-2006 at 5:31pm
keno
Sorry KENO I did not read this.
I understand, i musthave a right hand rotation.
Thanks a lot
Date Posted: August-16-2006 at 5:45pm
Date Posted: August-16-2006 at 9:31pm
Looks good...probably all the bells and whistles. Real clean, just like I thought it would be.Thanks Scott
------------- Scott
Date Posted: August-16-2006 at 10:20pm
it's not as clean as I would like it to be one day I'll break down and get the chrome primary and secondary bowls for the carb and the chrome intake when I get my heads finished. Good project for next years tax return.
Posted By: jbear
Date Posted: August-16-2006 at 10:27pm
79: Why doesn't my motor look like that? In fact I'm not sure what my motor looks like.
john
Date Posted: August-16-2006 at 10:36pm
I do....... STOCK cast iron gray.
Posted By: boat dr
Date Posted: August-16-2006 at 11:01pm
79 that was cold, real cold,in La. we don't talk about a mans dog his boat or his pickup truck ............boat dr
Posted By: The Dude
Date Posted: August-16-2006 at 11:17pm
nice engine pic.
When are you headed back to syracuse to get your boat?
http://www.correctcraftfan.com/diaries/details.asp?ID=717&sort=&pagenum=1&yrstart=1991&yrend=1995 - 95 Sport
Date Posted: August-16-2006 at 11:18pm
79nautique wrote:
it's not as clean as I would like it to be one day I'll break down and get the chrome primary and secondary bowls for the carb and the chrome intake when I get my heads finished. Good project for next years tax return. |
Hey Chris, between you, my partner, and me. We could make Correct Crafts look and run better than factory new!......Do you want to move to Ohio?
------------- Scott
Date Posted: August-17-2006 at 9:58am
depends on the pay
Date Posted: August-17-2006 at 5:13pm
79, I thought you had some aluminum exhaust manifolds... have you not installed them yet?
Date Posted: August-17-2006 at 7:38pm
I do have some new un-used edlebrocks waiting to be ported a little to match up to the heads I'm having done, I got all of the hoses and fitting but one. Need to figure out how I'm going to reduce the 1" line to feed the water to them. I've got anodized stuff for everything else but the one is givine me head acks.
Actually I had two set's sold the one set to joe he did a dandy job polishing them up you can see them on his post.
