exhaust manifolds hot 351w
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42752
Printed Date: May-17-2024 at 3:23am
Topic: exhaust manifolds hot 351w
Posted By: 428CobraJet
Subject: exhaust manifolds hot 351w
Date Posted: May-08-2018 at 3:59pm
wondering if my flow is enough on my engines...351w with crank driven water pumps into engine, thru thermostat to HiTek exhausts. the risers are more than warm. You can touch them but not leave your hand on them.
140 degree thermostat with 1/8 inch hole drilled.
------------- You are what you drive. 1971 Nova24vdrive 1967 Arabian
Posted By: Bri892001
Date Posted: May-10-2018 at 11:21am
Start off here: http://www.skidim.com/Faq_TROUBLESHOOT.asp#RWTS" rel="nofollow - http://www.skidim.com/Faq_TROUBLESHOOT.asp#RWTS
Post your results of the bucket test, and you should get some follow up advice.
Posted By: Gary S
Date Posted: May-10-2018 at 11:39am
I don't think you have a problem,I have the same exhausts on a PCM 302 and it feels hot too.. But then again so does my HM and my GT 40. Obviously a more accurate method would be better but I have never bothered to check mine as I don't think there is a problem. You cannot leave your hand on any of them.
Posted By: MourningWood
Date Posted: May-10-2018 at 11:46am
428CobraJet wrote:
140 degree thermostat with 1/8 inch hole drilled. |
This may not address hot manifolds, but you're engine will probably be happier with a 160/170 t-stat. Maybe buy (or borrow) an Infra-red heat sensor and check manifolds.
------------- 1994 Ski Nautique "Riot" 1964 Dunphy X-55 "One 'N Dun"
Posted By: JoeinNY
Date Posted: May-10-2018 at 11:59am
MourningWood wrote:
This may not address hot manifolds, but you're engine will probably be happier with a 160/170 t-stat. Maybe buy (or borrow) an Infra-red heat sensor and check manifolds. | The crank mounted pump is a hint that this is not the PCM cooling setup that many of us are familiar with – who marinized the engine? Is there a circulation pump? Pictures would help, along with some better temp data.
1967 Mustang 302 "Decoy"
Date Posted: May-10-2018 at 12:10pm
JoeinNY wrote:
The crank mounted pump is a hint that this is not the PCM cooling setup that many of us are familiar with – who marinized the engine? Is there a circulation pump? Pictures would help, along with some better temp data. | Craig, ???? Is one of the 418's the engine????
428CobraJet wrote:
I'm building a couple 351w strokers (418cids) for my 1971 Nova 24 Vdrive. Craig |
BTW, I too have never found a engine that you can leave your hand on a exhaust manifold.
Date Posted: May-10-2018 at 12:47pm
it's a Holman Moody marinization. with crank mounted pumps.
maybe it's the thinness of the stainless headers. I'll look for my infrared gauge. and a photo!
Posted By: JoeinNY
Date Posted: May-10-2018 at 1:01pm
They likely wont run real cool, but if they are getting up there to boiling temps you are going to need to be careful for sure. If they are new strokers make sure you are not being too aggressive with the timing. 418s would need to much less total timing ( but possibly more intial timing) than a 351w and running them with a stock curve and too much timing will get everything hot - until it blows up.
Date Posted: May-10-2018 at 2:02pm
I can touch them. I just can't sit on them.
