Mustang Issue
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=41130
Printed Date: May-18-2024 at 7:44am
Topic: Mustang Issue
Posted By: theclaryproject
Subject: Mustang Issue
Date Posted: May-27-2017 at 1:32am
I have a 1971 Mustang with a Chrysler 273. NEVER had a problem with the boat. I've taken it out probably a dozen times this year already. Just the other day the boat was low on gas when I took it out, while riding I throttled up to go faster and the boat started to die. I slowed down and now can't go above idle without the boat sounding like it wants to die. It sometimes will do full throttle but will not run as fast as it should.
I have : 1) replaced the fuel and refilled the tank 2) checked fuel pump and fuel filter 3) cleaned the carb.
Tonight I put it back in and it ran perfect for about 30 minutes then did it again and now Im back stuck again.
Any thoughts??
------------- 71 Mustang
Date Posted: May-27-2017 at 6:56am
Nathan, Fill us in some more on what you did to check the fuel pump. The best way is to tee in a pressure gauge. Also check your anti siphon valve at the top of the fuel tank to make sure it's clear. Do you have a point set in the distributor or has it been converted to a EI?
