Overheating on the river but not at house?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=37158
Printed Date: May-18-2024 at 10:21am
Topic: Overheating on the river but not at house?
Posted By: MarauderMatt
Subject: Overheating on the river but not at house?
Date Posted: August-23-2015 at 8:38pm
Ok so when we are in th driveway with water hose connected never gets over 160 degrees. I just bought the boat and replaced water impellar. Thinking she is good to go, take boat out at river and within 5-10 minutes overheated. Where do i start and what else do i need to change out? I own a 1976 Ski Tique. How can i test to make sure the water impellar is priming the system out of the lake? Any help would be greatly appreciated. Trying to get this running right before season is over lol
Posted By: 71CCMartinique
Date Posted: August-23-2015 at 8:55pm
Is it possible that the t stat is giving you trouble? Mine opens about 165 degrees.
------------- ....and the adventure continues.
Date Posted: August-23-2015 at 9:10pm
if it was the t stat woudnt it overheat in driveway too?
Posted By: Gary S
Date Posted: August-23-2015 at 9:21pm
How did you hook it up to the hose at the house?
Posted By: CrazyCanuck
Date Posted: August-23-2015 at 9:25pm
Bucket test.
------------- https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Date Posted: August-23-2015 at 9:33pm
CrazyCanuck wrote:
Bucket test. | can you explain the bucket test
Date Posted: August-23-2015 at 9:38pm
there is a slight drip of water coming from water impellar pump. but its not that much and its been leaking at this spot for about 2 years with no issues before.
Posted By: Gary S
Date Posted: August-23-2015 at 9:48pm
Gary S wrote:
How did you hook it up to the hose at the house? |
Date Posted: August-23-2015 at 9:50pm
plugged the water hose into a fitting rigged up, opened the valve
Posted By: Gary S
Date Posted: August-23-2015 at 9:54pm
Here is the bucket method,disconnect the intake hose and 1- either connect a longer hose and put into a bucket or 2- put a fitting into the side of the bucket and connect the hose to the intake hose. This way the system is not pressurized by the house pressure,the engine pump must do the work just like at the lake. This is why I asked how you hooked it up at home---
Posted By: Gary S
Date Posted: August-23-2015 at 10:02pm
MarauderMatt wrote:
plugged the water hose into a fitting rigged up, opened the valve |
When you connect it up like that you dont even need the raw water pump! That is why you see water leaking too,any leak with pressure will be sucking air when under suction. Take a glass of water and a straw,cut a hole in the straw an inch higher than the water and try drinking it. That is what your pump is trying to do,thats you at the lake. If you were able to pressurize that straw,some water will leak out but the engine would get enough to keep cool while it ran,thats you at home on the hose.
Date Posted: August-23-2015 at 10:52pm
Sorry. I should have elaborated. Gary caught it. On my boat, I unhooked the hose from the oil cooler and then that gave me lots of slack to put in in a bucket of water. You want to see if the impeller is actually drawing water in.....
Date Posted: August-23-2015 at 11:23pm
since the Raw Water Pump has a slight leak, do i need to replace the whole unit? is so whats the part number? i hear they are expensive
Date Posted: August-23-2015 at 11:29pm
Where is the leak coming from? If from a hose connection then no, but if its the shaft, then yes maybe.... Can you post a pic of what you have?
Date Posted: August-23-2015 at 11:56pm
looks to be coming from a tattletale, maybe from the shaft? ill have to take a closer look when i get a chance
Posted By: spiralhelix
Date Posted: August-24-2015 at 12:50pm
The RWP can be rebuilt. Pretty sure Gary has done them. A new one is pretty expensive. I believe I paid upwards of $400 for mine.
im sure you can get parts from http://www.skidim.com" rel="nofollow - skidim.com , http://www.marinepartssource.com" rel="nofollow - marinepartssource.com , http://nautiqueparts.com" rel="nofollow - nautiqueparts.com , or http://www.n3boatworks.com" rel="nofollow - n3boatworks.com
Most of them have 10% off with codes or CCF membership.
Date Posted: August-24-2015 at 7:14pm
| +1
Date Posted: August-26-2015 at 1:21am
well, did the 5 gallon bucket test and found the pump was blowing water out instead of sucking it in lol....flipped the pump around and sucked down that 5 gallon bucket of water in seconds!!! My question is there is a flat head screw on the pump that was on the outside where it was visible. I flipped that pump over 180 degrees now the screw is on the inside where u cant see it. But for what ever reason is sucks great now?
Posted By: Gary S
Date Posted: August-26-2015 at 2:03am
That screw holds the cam in place inside the pump. Placement of the cam determines which way the water flows thru the pump. The position of that screw facing in or out depends on the rotation of the engine. Facing in for a left hand engine,out for a right hand engine. Your engine is a lefty which is a whole nother story--- glad you figured it all out.
Date Posted: August-26-2015 at 7:43am
| https://www.youtube.com/watch?v=ECv1VwW6RTo" rel="nofollow - How a flexible impeller pump works
Date Posted: August-26-2015 at 8:34am
Careful Gary, you're assuming he has a PCM. Commanders and Escorts were available in the mid 70's and they put the pump on the other side of the engine. Pictures woul help here.
Posted By: Gary S
Date Posted: August-26-2015 at 10:11am
Oops I did
Posted By: Hollywood
Date Posted: August-26-2015 at 10:49am
This is for PCMs, but gives you an idea of what's happening inside a RWP anyway. http://s134.photobucket.com/user/kfleisch/media/boat%20parts/impellers.jpg.html" rel="nofollow">
Date Posted: August-26-2015 at 5:40pm
Gary S wrote:
That screw holds the cam in place inside the pump. Placement of the cam determines which way the water flows thru the pump. The position of that screw facing in or out depends on the rotation of the engine. Facing in for a left hand engine,out for a right hand engine. Your engine is a lefty which is a whole nother story--- glad you figured it all out. |
how do i tell if its a lefty? and if it is then why is that a whole nother story?
Date Posted: August-26-2015 at 5:43pm
TRBenj wrote:
Careful Gary, you're assuming he has a PCM. Commanders and Escorts were available in the mid 70's and they put the pump on the other side of the engine. Pictures woul help here. |
pump is on driver side of engine, i believe its a PCM engine,
Post pictures of the engine and prop.
Date Posted: August-26-2015 at 5:49pm
old pic but should be able to tell if not i can get more later when i get off work
Date Posted: August-26-2015 at 5:51pm
RWP pump is in orange bottom left side of pic
Posted By: baitkiller
Date Posted: August-26-2015 at 6:15pm
Ill leave the fuel line and filter for you guys.
------------- Jesus was a bare-footer.............
Date Posted: August-26-2015 at 6:24pm
Not good. Post a pic of the prop.
Date Posted: August-26-2015 at 8:42pm
i said it was AN OLD PIC geez....
Date Posted: August-26-2015 at 8:44pm
whats not good.....i said it was AN OLD PIC geez....can we stay on topic, now back to the RWP is this a left hand engine?
Date Posted: August-26-2015 at 9:01pm
MarauderMatt wrote:
whats not good.....i said it was AN OLD PIC geez....can we stay on topic, now back to the RWP is this a left hand engine? |
TRBenj wrote:
Not good. Post a pic of the prop. | The prop picture will answer your question about the engine being a LH or RH. The picture of the engine was to confirm the trans type.
Date Posted: August-26-2015 at 9:03pm
baitkiller wrote:
Ill leave the fuel line and filter for you guys. | Well, I'll jump in and mention the potential BOMB!!! Yup, another back yard job!!
Date Posted: August-26-2015 at 9:16pm
8122pbrainard wrote:
guess u missed the "ITS AN OLD PIC" as well smh
Date Posted: August-26-2015 at 9:23pm
guess u missed the "ITS AN OLD PIC" as well smh | That's a relief that you replaced the fuel line with USCG approved. How about an updated picture.
Date Posted: August-26-2015 at 9:42pm
Not good meaning Gary is correct- the pump orientation you cited likely indicates a LH engine (which would be confirmed by a pic of your LH prop). That has a number of poor handling issues associated with it on a boat that small.
The fuel rigging shown is also quite concerning, hope you got it squared away since the pic was taken.
Date Posted: August-26-2015 at 9:56pm
yes sir, thats some good info...ill get you that pic of prop soon as i can pull boat out of garage enough to snap a pic
