Fuel tank removal '95 SN |
Post Reply | Page <12 |
LooseScrew22
Groupie Joined: August-05-2022 Location: Oregon Status: Offline Points: 47 |
i assume it is due to the corrosion in the plates and gaskets. I am replacing all of the fuel lines and i am having a custom fuel pickup plate and gasket made as these are not available. i also ordered a new fuel sender unit. once this is all back in place, i cannot think of a reason why the boat should have a gas smell...only time will tell.
PM me if you want the dxf files (drawings) for the plate/gasket. If you are interested in purchasing, i can ask the fabricator if he would want to make additional sets |
LooseScrew22
Update-
Replaced all the fuel lines to the engine from the gas tank. I 3d printed a replacement fuel line clip and installed them in place of the factory zipties (the grey hose is for the shower). I am planning to head to the lake to see if there are any leaks from the rudder/driveshaft before putting the gas tank |
Very nice work. You'll be happy with your efforts once it's back in the water.
You are making progress quickly, you will have a reliable boat this year and just in time for the season.
LooseScrew22
LooseScrew22
tank is now back in the boat
and i hope i never have to do this job again! i still have to tighten all the bolts to final specs. turns out my fuel line clips hold the hose too high on the wall to clear the bolts for the tank straps. Had to drop the shower hose and shift the lines to the bottom two clips. |
Nice work. Hopefully you won't have to go through that again. I really like the concept in the new SN with the center fuel tank. Too bad these older boats have the rear tanks and all the "fun" that comes with them.
LooseScrew22
