1995 ski Nautique steering issue |
Fresno1995
Newbie Joined: October-25-2020 Location: 93720 Status: Offline Points: 6 |
Posted: April-12-2021 at 1:19am |
new to this . Please need some help with 1995 garage find ski Nautique. Steering was two handed driving last year.
Had a plan to order steering cable in december from Nautique Parts . Ordered the OEM cable. Got is switched out , greased the tube in back and helm up front. Got it in the water for a test drive and worked fine until I took a turn around the turn island on man made lake and had to go with two hands . placed in neutral and steering was fine . under a load and in turns it is tight . Do i have a rudder box issue ? thank You
Glenn in Fresno
rebel skier
Gold Member Joined: October-17-2014 Location: Middle Tenn Status: Offline Points: 771 |
Likely yes. I did the same thing. I replaced my steering cable convinced it was my problem while neglecting the rudder. Re-packed my rudder and that solved it.
Grab your rudder and see if it has a lot of play. There is a good YouTube about how much play you should have. I sent a message to Nautique parts to figure out what size packing rope. Get extra it’s cheap and it’s harder to cut the right size than you think - just takes a little practice. The FAQ here about repacking the rudder I believe is a similar year SN as yours |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2842 |
Re-pack the shaft seal and apply grease to the rudder shaft zerk fitting. That should help significantly.
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 886 |
Curious..what prop is on it?
1994 Ski Nautique "Riot"
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2065 |
Make sure your packing nut is properly tightened against the jam nut on your rudder port.
