difficult start & high idle |
dgabler
Groupie Joined: June-12-2017 Location: Atascadero Status: Offline Points: 71 |
Posted: December-31-2018 at 10:30pm |
1988 SN 2001 PCM 351
I am having some issues and I am not sure of the solution so I am reaching out for advice/direction. First: After the engine is nice and warm it does not always want to start back up. When cold or sitting overnight it will start right up typically. The issue crops up typically after a skier change and I need to pump the throttle twice and give it one or two start tries, then it will typically start. I did search the forum and found that there were two possible issues: 1. fuel running down carb barrel after turning the ignition off and 1 fuel in the clear flex line from the pump but in my case neither of these issues is happening. A video is here: https://youtu.be/23t55ZQUmBM Second problem: When cold I have a nice slow idle however when the engine warms up the idle is much much higher, is there anything I should fix/change for this? I did attach a vacuum gauge and adjusted the needles to maximum vacuum but these same settings made starting nigh impossible so I undid my changes. Much thanks for your input! |
SNobsessed
You might want to check to see if the coil is getting hot when it is having the problem.
dgabler
Coil was toasty. Changed the coil and it seems to start easier. Still have to pump the throttle to start but seems to catch easier.
WakeskateNW
Groupie Joined: December-08-2016 Location: Lake Tapps, Wa Status: Offline Points: 65 |
what happens when you set your idle after it’s all warmed up?
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3333 |
Sounds much like idle mix is too lean
Repeat your idle mix/vacuum setting procedure, but do it while in gear, in the water. Have an assistant or tie up to your dock. You will settle on different setting. that will improve throttle-free starting and consistent idle in/out of gear. |
River Rat to Mole |
shierh
Make sure secondary is closing all the way. I found this on mine.
dgabler
Was having issues of keeping the engine idling after warmup - specifically noticed when re-fueling at the gas dock. Could not keep the engine idling in gear (no wake). Had to run a bit higher RPM.
Previously had tuned the idle screws to max vac at idle they were at 1.25 & 1.25 turns out. Followed the turning procedure of finding best setting and settled on 1.75 & 1.5 (driver/passenger side) on the fully warm engine at no-load idle will have to try doing the adjustment when under load next time at the lake. Last time I tried using the vacuum and adjusting for highest draw it was extremely difficult to start, but I did that as a curb/no load idle adjustment. Thank you for all the hints. |
dgabler
Made the suggested adjustments while under load (ended up turning screws out 1/8th more) and what a difference. Boat starts much easier now and idles even better. Thank you all!
Had some great runs at Shasta this past week! |
