Typical guide post height? |
Orlando76
Posted: December-01-2018 at 6:08pm |
Had my guide posts replaced with newer Ramlin style possibly from 14-18 era. They need trimmed down some. How high are they typically above the side of the boat? Right now mine are about 42”. I’m thinking they should only be about 15”?
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3974 |
GHTILL
Senior Member Joined: July-29-2018 Location: Aledo Status: Offline Points: 172 |
Many would say the taller the better.
TWSS
GHTILL
TWSS
Orlando76
Both of those are real good looking 93’s. Sounds like a silly question but cutting 30” off a guide post just Sounded ridiculous. Gregg, I was thinking about those same wheels on my 93 but I’m too nervous to deviate from the originals.
GHTILL
The wheels were not that expensive. Remember the "originals" can rust. These won't
TWSS
GHTILL
TWSS
shierh
Had mine made at sunshine welding at the coast. aluminum.
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 758 |
You know you can adjust the height on most 90s ones underneath, Always better to have more than not enough when its windy or a deep ramp or at night...
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3595 |
My guide posts measure 18" above the side of my boat resting on the trailer.
These are unique with ABS plastic pipe covering my guide posts, the plastic allows the pipe to rotate if the boat presses against it while sliding up on the trailer.. There are bumpers that work as padding on the guide post but they also work as floaters, when I launch on steep ramps the plastic pipe will float up extending my guide post when needed. I don't think this is strong but it sure works as a guide when the trailer goes in deep. Not sure if it was designed to do this or just a bonus fluke of manufacture but it works well. |
rosconole
I think after about 93 they started doing that 96 does have the pvc over the guidepole extra high. , Personally I like it. my 89 and 91 are old school 91 you can adjust to boat . 89 is bolted to frame.
