Prop suggestion |
ben.b
Newbie Joined: August-19-2012 Location: Newnan, Ga Status: Offline Points: 30 |
Posted: July-10-2018 at 10:44pm |
Bought a 94 ski Nautique and looking for a prop. Research leads me to acme 422 or 612 I think. Will barefoot some and skate some with ballast at about 900 lbs. Thanks.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2842 |
ACME 654 or 1868 if you plan to do a lot of slow speed runs with a lot of ballast.
JQ |
There were at least 4 different engine/transmission options in 94. It would help to know which you have.
ben.b
5.8 HO. 1:23-1 transmission. Dont want to lose top end if I can help it. Ran 45 mph on gps Sunday at about 4800-4900 rpm. Tach is a little shaky. Protec ignition (I know) and carb. Thanks for the reply.
Jonny Quest
I run a 654 on the the 5.8 H.O. with carb & distributor. At 4,400 feet of elevation, I run 43 mph at W-O-T.
JQ |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
Shoet, concise and right to the point |
ben.b
Thanks for the help.
