Outboard fuel issue |
winniskier
Senior Member Joined: March-15-2008 Location: Gilford, NH Status: Offline Points: 193 |
Posted: August-26-2017 at 8:31am |
I have a 4 hp 4 stroke outboard on my sailboat. It runs great when it gets fuel. I use an external tank at the other end of a six foot hose. When pumping the priming bulb, it sounds like air is being blown back into the tank. This happened with the new hose and the one it replaced. Is this normal? Is there a check valve in the tank?
Jim
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10708 |
Primer bulbs have and inlet and an outlet check valve in them.
They're spring loaded ball check valves. There's no check valve in the tank It sounds like the inlet check valve is leaking or you have the bulb on backwards. Usually there's an arrow on the bulb that should point toward the engine. Maybe the new bulb is defective |
The aftermarket bulbs are junk. Get an OEM one, it will work much better.
skutsch
I suppose it really doesn't make sense to run a fuel pump, regulator and return line for a 4 HP, but that is how my outboard is set up... HA! Sounds like these guys have you headed in the right direction.
winniskier
I just bought a OEM primer bulb and swapped out the old one, confirmed for the 1oo0th time the arrow point toward the engine. Still same thing -- bulb is soft, When it is squeezed, I can hear air going back into the tank. When released, no feel of fuel being drawn from the tank., Repeating many times does not change things. Any ideas?
Jim
Maybe the oring on the hose/tank connector is bad, allowing air to be sucked in.
You could test this by hooking up a line to the bulb & pulling directly from a can of gas. |
shadow
Newbie Joined: July-27-2015 Location: badin lake, nc Status: Offline Points: 34 |
The pick up tube in the fuel tank may be cracked sucking air, the primer bulb would not pump up tight on my outboard this year and that was the problem, had the same problem 4 years ago. Drop a fuel line direct into the tank, if the bulb pumps up tight that may be the problem, I made me a pick up tube out of copper this time.
shadow
