  New Posts New Posts RSS Feed - Holley 4160 450 CFM
Holley 4160 450 CFM
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Topic: Holley 4160 450 CFM
    Posted: April-23-2017 at 10:56pm
If anyone has a Holley 4160 450 CFM carb available, I'm looking for one for our 302 Commander. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2017 at 12:05am
By now you've probably figured out that those are hard to find. Holley sells refurbished ones on ebay,last year I passed one up for around 300 thinking they would have more. They just had another but it it had gone up 78.00. Bought it anyway it looks brand new. Maybe you could contact them and see if they have any more    ebay link
scootdogydog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scootdogydog Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2017 at 2:17pm
David -- You're looking for a Holley R7159. Do you have one that you want to rebuild? 703-33 is the holley marine renew kit for that. I do know that you can put a larger CFM carb on it. What's on it now?
1999 Python
1980 Ski Tique
1968 Mustang WIP
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 12:23am
Current carb is a Edelbrock 1409 600 cfm marine carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 8:46am
There are many different LIST numbers associated with 450cfm marine Holley's. It is not recommended to put a 600cfm on a stock 302.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 11:40am
David,
Curious as to why you want to swap out the Edlebrock. I dont recall reading anywhere that you were not happy with the boat's performance. I ask the question because I have been pretty happy with my Edelbrock for the past 13 years. I find it less fussy than a Holley, which I had previously.
I should start being up at Gregs fairly periodically now. Hope to see the new Tique soon. Plus it's time for you to resume your barefooting training.
shadow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shadow Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2017 at 2:15am
David, I have the stock holley carb that came off of my 78 ski tique. it has the 302 commander motor also. Last year I thought I was having carb problems, so I replaced it with a 600 quick fuel marine carb, turned out to be a fuel pump problem, so I think my stock holley carb is ok. The 600 quick fuel carb ran great after I installed the new fuel pump, by the tach the boat picked up about 200 rpms, but it dripped fuel when you shut it off, I did not want to adjust the float levels to compensate for the angle of the engine so I installed a 12 degree wedge plate under the carb to level it up. it runs great on the trailer and no more drip, let the motor get up to temp, shut it down for 5 min. it fires right up. If it runs as good on the water as it does on the trailer I am going to keep the 600 quick fuel carb on the boat. If you want to give the stock holley a try give me a call. my name is Jerry, phone number 336-339-3428, I think I remember meeting you at the correct craft mini a couple of years ago, I had the red ski tique. I live at Badin Lake now, let me know if there is anything I can do to help you out
shadow
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2017 at 8:57pm
Thanks Jerry. I remember you and your boat. I'll shoot you a text
