Best way to replace cutlas. |
Post Reply | Page <123 |
quinner
All you need is a blowtorch and a pair of pliers, ya hear me Hillbilly Boy??
SWANY
Yeah, the packing in the nut for the rudder, thats what I should have said
Only if you're sure that 1) it's bent and 2) you're not going to reuse the coupler. Else you're potentially flushing $350. Removing the coupler is also easiest when you have a matching stationary pushing point (like the trans output flange).
Otherwise, by all means- sawzall! Shaft packing (assume you meant driveshaft, not rudder) is a good idea too. 1000x easier while the shaft is out. |
SWANY
Then just cut the old shaft out and be done, easiest way going about it IMO. Packing on rudder also while its out. I'm only hobbist though |
Going ARE if your shaft is bent is not a bad idea... it's the same price (or cheaper) than a new single taper shaft + coupler. If your coupler is good, I might price out a shaft-only replacement though? If close in cost, dual taper is pretty nice.
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
Sorry, I'm NOT removing the strut. Just the shaft and replacing the cutlas. Might have to get an A.R.E.
1999 Ski Nautique 196
Hobbyist here... I know how long it takes me to remove, reinstall and realign an engine. With my facilities and equipment, it's easily a half day project if I hustle... full day if I take my time. I can do a shaft r&r plus bearing replacement in a few hours- either on the lift or on the trailer. Just speaking from experience.
Of course, if the engine is coming out anyways you bet I'll be throwing a cutlass in while it's out. That's $50 and 45min well spent. |
Clearly it's not just me, the resident PROFESSIONAL doesn't fux with them either. Later hobbyist...
Dealing with interference fit couplers is not hard. Ignore HW, he has an unnatural fear of coupler removal/reinstallation (don't think he's ever done one).
You mentioned removing the strut... now that is something I would try to avoid at all costs... getting it perfectly lined up when reinstalling can be pretty tricky. Not hard to r&r the bushing while it's on the boat. |
I haven't seen anyone remove a coupler with a puller. Not even sure there's room to try.
Jody was just talking about how he pulls the engine to install the XPC dripless shaft seal. I'm rolling the engine in spring to do a cutlass. Fussing with the interference fit couplers is indeed nonsense. |
Frankenotter
So I was about ready to charge down to my heated hanger with the intent of pulling the shaft out of the 176. This was a 2 birds one stone scenario.
1. The cutlas bearing has too much play 2. I suspect the shaft is bent a little. I was just going to bring a prop puller, remove the rudder, and use a 3 jaw puller for the flange. Now I've been seeing a lot of people talking about removing the engine instead of removing the trans coupler. Is it THAT hard to get the coupler back on? I know it's tight, but I was picturing an oven and some aerosol to get her back together. Is it not that easy? I hate the idea of pulling the engine when I'm not sure the shaft is good anyway. Chris |
