Floors |
bigwavedave
Senior Member Joined: March-08-2006 Location: United States Status: Offline Points: 199 |
Posted: March-13-2006 at 9:16am |
I have removed the foam from my 69 Correct Craft Mustang. You guys were right--long, hard job. I now need to know what type of flooring I should install, and what thickness should it be. Should I try rejuving the original fiberglass flooring shell to keep the boat as original as possible? Does anyone know how many sheets of flooring material I would need to purchase? Many thanks, Bigwavedave
bigwavedave
Tim D
I used 3/4 treated plywood, put 7 coats of polyurethene on it and used silicone on all the seams. If you glass over wood, all it takes is one crack to trap water and cause it to rot again. I also shimmed the floor (slightly)toward the motor box so water will not get trapped against the walls. Talking about being a hard job, someone before me installed the floor with slotted brass screws, my dewalt would snap the heads off, so I had to unscrew each one 2 or 3 turns by hand before before using the cordless. I used 2 sheets of 4x8.
Tim D
