Dorsey trailer trouble |
wetneck
Groupie Joined: December-17-2011 Location: FLA Status: Offline Points: 66 |
Posted: March-25-2012 at 2:49pm |
with my 99 ski came a dorsey trailer and i always have issues with the tongue, on and off.... what am i doing wrong/not doing ???
if it was removable without torching it would be gone already, but it DOES hold tight but what a pain... any tips/tricks ??? |
SN206
Grand Poobah Joined: February-25-2009 Location: Fort Worth, TX Status: Offline Points: 2339 |
Can you be more specific?
wetneck
in dropping ON ball is not as difficult as lifting off... usually takes me about 10 mins....i lift top release and just always have a hard time lifting off....always clamps on.. have to use a pry bar half the time to lift tongue off ball...SO much harder than any traditional hitch ive owned
I cant see any other easier way to engage/ disengage and just looking for any input |
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
Have to be careful here talking tongues, nuts,and balls or I will end up on someones tag line. What size hitch ball are you using? does it match the numbers on the coupler (I know very basic, but that is the best place to start). Is the latching mechanism well greased? There is a large nut on the bottom of the latch mechanism (bottom side of trailer tongue) that adjust how tightly it couples, try loosening it a little.
1987 Ski Nautique |
SNobsessed
The coupler could be distorted, a trailer shop can replace it for you, $100 tops even if it is welded on.
east tx skier
Senior Member Joined: August-22-2006 Location: Tyler, TX Status: Offline Points: 248 |
On mine, you drop it as if the front of the tongue is fitting tight over the front of the ball (snicker). In other words, the trailer is as far back as it can be and still fit over the ball. Works well that way.
As for getting it off (snicker), I just raise it up and if it hasn't released easily, I just rock it back and forth a bit and off it comes. |
SN206
Can you take a picture? Dorsey change their actuators several years ago.
east tx skier
This is the best one I have.
SN206
Ya that's the older of the two actuators. If that is the one you have and if needed to be replaced, it would be the cheaper of the two to do so.
east tx skier
Is yours UFP? That's what I had on the old MC trailer if I recall. Never had much trouble with it. Just a bit different.
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1749 |
Don't think there is a nut underneath those that can be loosened or tightened. Try backing the trailer in the desired spot then chock the trailer wheels. Then pull up slightly to take the pressure off that actuator. See if that works if you haven't tried that already.
wetneck
it is just like yours E.T.S. think i finally understand how it works, with a lotta lube too... freed up the release pin on starboard side also that IS the prob tho... you need to chock wheels and move vehicle... so much more work than the traditional tongued trailer, my 25' ocean boat unloads SO much easier thanks for the replies and suggestions ! |
jimsport93
Once you get it loosened up it should work fine. Just remember to give the trailer a tug forward before trying to uncouple it.
