#2 and #3 trailers |
Posted: January-03-2012 at 9:27pm |
That #3 on our old Cuda was bought new in about 73-74. It wasn't a 60's trailer.
I agree... those look to be similar in size to the wheels on my (former) Ski Tique, which are 14".
Those etrailer wheels look good to me. We're trying to replicate this which look bigger than 13's to me:
Bruce, are you talking a 60's #3? Those could have had 13" wheels originally, as the #2's of the era had 12". So you can probably go 13" or 14" without it looking out of place... my '67 #3 currently has 13" wheels, but Im planning to go with 14" eventually- probably trying to do something similar to Pauly Banana's '68 SN:
Etrailer sells some old-school steelies like that- Id add some baby moons to them! 14" wheel at etrailer |
peter1234
Hi Bruce the drivers side rail has a twist in it i cant get out completely i might not have to worry bout it , i was playing with it trying to get the bow out of it and was struggling it is probably fine. f anyone is looking for square u bolts look at jamestown distributors part # scp57461 it is 1/2 " square bend .3 1/16 span 5 5/16 length . 2 inch thread . bruce also northern tool probably has the tires and wheels for you
Peter, I'll have to make time to get it asap, before the snow flies, (if it ever does). I would like to have it painted by spring. I'll give you a call. Why are you going to replace one of the rails on your #2?
Tim, do you know a decent source for original type wheels? I believe they are 14". |
peter1234
Thanks Tim I am going to at least replace a rail on my # 2 . Bruce your #3 is ready for you here i am just waiting on u bolts but i can get those for you later . also dont worry about leaving it here as long as you want .
Oh, and if you wanted to pop out a few plates that allowed us to mount a standard A-frame jack where the original jacks sat, Id be in for a few of those too!
Peter, 2200 lb would be just fine for the axles and hubs- the 12" and 13" wheels/tires are going to be the weak point anyways. You should be able to get a wheel and tire combo for <$200/set as well. Think cheap (like Correct Craft did)... 4-lug steelies. Like these: 12" wheel from Northern Tool for $30 12" tire from Eastern Marine, 1045 lb capacity (each) for $43 On the couplers, I actually found the same ones that CC used, after much searching: $40 coupler from etrailer Dont forget that unless you'd be selling them with "some assembly required", then they'd also have to be painted, and finished- meaning fenders, lights, wiring, chains, carpeted bunks, etc. I think theres a "want" for a handful of them, for sure... whether or not theres a market for them, Im not quite as confident! Once you add up what it would cost to build them, then add a reasonable upcharge to cover your time and effort, there may not be many takers. Thats been my experience on a few of the "hard to find" custom made parts Ive had done up. I still think its worth going through the effort of tallying up the costs though! |
peter1234
that seems reasonable for a limited run item , there is pretty close to a grand in labor i would say just to build the basic trailer .
Peter, someone was doing #3s a few years ago. There was a link on the site. I believe they were around $2k without the options.
peter1234
has anyone tried to repop these #2 trailers? I have one here from Bruce and just steel wise the 2x3 channel
2- 20 ' lengths = 140.00 1 -10' l for cross braces 35 10' length channel 1 1/4 appr 45 tongue 25? spring and axle kit 250 3k lb two wheels and tires250 misc hardware , lights wiring jack . it cant all be 800 in materials? correct me if i'm way off what are they worth reproduced? and how many could someone expect to sell? |
They are carpeted Bruce just like the bunks.You just can't get your hands behind them to clean,they are that close.
Gary, Don't those things marr the finish on the gel?
You almost have convinced on taking them off,it would be easier to clean up the hull.
Yeah, not sure of the reasoning beyond there being 2x as many bolts holding down the taller stops. I do know that both my Ski Tique and BFN with the taller stops used the smaller u-bolts, while all of the short style stops used the larger hardware. I think I'll pass on those guides! |
Maybe Peter could make you up a couple of pairs of the goofy side guides
[QUOTE=TRBenj] Gary, the tall bowstops with 4 u-bolts used smaller hardware (3/8") than the short bowstops with 2 u-bolts (1/2" hw).
QUOTE] I would have thought they'd be the same and the fact the taller ones would have more leverage on them that they would be the heaver ones.Maybe the larger base made up for that |
My Uncle Todd measured his #2 and confirmed the measurements above (3" x 1-3/8" channel).
Gary, the tall bowstops with 4 u-bolts used smaller hardware (3/8") than the short bowstops with 2 u-bolts (1/2" hw). Al, good heads up on Caterpillar possibly having the u-bolts... its always good to have a backup plan! The 80's CC trailers got beefed up over their 60's-70's counterparts. The #3 went from 3" to 4" channel and the #4 went from 4" to 5". |
peter1234
thanks i am looking for 60s era but I think we are all set
DrCC
Neighbors '88 Barefoot trailer has 5" channel with the original 3/8" U-bolts.
quinner
FWIW, just measured the Martinique trailer, 4" with 1.1/2" flange and the bow stop is 52.1/2" tall. |
DrCC
Half inch originals ?
Caterpillar Dealer has those. |
Chris, the hose is working great,does not seem to have any wear and it does not damage the rub rail and that is after the 3K Florida trip. The only thing I could say about the experience is that the vinyl on the motor box balloons up as you drive, much like a convertible top does.I think if I did it again that I would use some kind of strap to hold it down.You guys with glass boxxes don't know what your missing
peter1234
Thanks everyone . I dont know how hard to find they are but I deal with a locl spring shop and he can make what appear to be the right ones .
These are Marine ones Al,there is about a 30 dollar difference |
storm34
Not going to make it home over lunch but I'm sure my measurements are the same as Gary's.
Like Tim, I haven't been able to find the U bolts and will have to cut mine off since they are rusted. Gary, how's the hose holding up against the rub rail? |
If you can find some, let us know! The largest Ive been able to find are 3/8"... quite a bit smaller than the 1/2" originals. |
DrCC
So, what's the deal with U-bolts?
Did they become rare all of a sudden? Any farm supply store should have them. |
Peter,mine measures 3" high, 1 3/8" wide. My U bolts measure 2 3/4" wide but that is for this kind of bow stop.
