rope trim help!!!! |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21131 |
Posted: August-24-2009 at 4:30pm |
I put 5/8" in my '78 Tique... Brad put the same in his '86 SN. I dont think 1/2" is correct, but Im sure it went in much easier!
gun-driver
Is 1/2" the right size rope? I will be putting new rubber and rope on my '85 soon and I thought I saw a tread that said it was 5/8 rope.
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5312 |
No problem David, glad I could help.............. Naw, I ain't da man but just remember one thing: "You'll only get out of this site what your able to contribute to it!" |
Hooty222
Senior Member Joined: May-10-2009 Location: Flagstaff AZ Status: Offline Points: 141 |
Hello, I did that post awhile back..... Search for (Rub Rail ROPE Install tool)
1986 Ski nautique 351
1988 Barefoot nautique 454 |
rookie
Groupie Joined: July-26-2009 Location: florence,ms Status: Offline Points: 74 |
thanks Morfoot for getting the ole brain working...went in much more easily! looks fantastic!!
you are the man!!!!!!!!!!!!!!!!!!!!!! rookie |
do it right the first time...
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3889 |
Rookie,
I also saw where someone has a thread showing that he used a Boxed End Wrench to feed it through. The Cooper Pipe sounds like the ticket. Do a search and you will see the picture of the Boxed End Wrench. Remember that the search function does not go back but a few months. You have to go to the advance search function and set it to search for a year, I think. I wish it would go back even deeper. Donald |
rookie
thanks i will give it a try.
Morfoot
Pull the boat out in the hot August sun so that the rubber will heat up and become a little more pliable. I just replaced mine about 3 weeks ago and it took me longer to clean all the mildew and dirt out of the track than it did to replace the rope itself.
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
Go buy a piece of copper tubing, I think I got a 3inch piece at Lowes, put the pipe in the rub rail and feed the rope into the pipe. You will be done in no time. If the pipe doesn't slide to easily spay a little soap and water to make it slide.
rookie
i pulled the old rope trim out and purchased 1/2" nylon rope to replace it ...but i have tried everything and in over 1 hour have only managed to get about 2 ft back in>>> is there an easier way than putty knives and brute force? 78sn
please!!!! dave |
