More on alignment |
winniskier
Senior Member Joined: March-15-2008 Location: Gilford, NH Status: Offline Points: 192 |
Posted: July-20-2009 at 11:17pm |
After running the boat for 3 seasons without checking the alignment, I decided it was time. I removed the bolts and determined the plates to be stuck, perhaps rusted, together. I spun the shaft from inside the boat. The small amount of resistence was symetrical and consistent. I tapped a small screwdriver into the seam and gently tapped the plates with a hammer, but I could not get the plates to separate. I did not want to do any damage trying to force them apart. Nothing suggested that the shaft was out of alignment. I never had a chance to use my gap wrench. Am I good to assume that my boat is in aligment?
Jim
gcll
Groupie Joined: June-05-2009 Location: Prattville, Ala Status: Offline Points: 91 |
Mine were rusted together also, I used a chisel and hammer to get them apart- then used a file to clean up the chisel marks and a drimel with wire brush to remove the rust, no harm done- my alignment was way off, now my boat runs alot smoother.
BuffaloBFN
You know where that word leads. From what I've seen with my own boats and a few others I've turned a wrench on, I'd say your odds of having good alignment are less than 50/50. I've even seen a couple that were visually out! Split the coupler and take a look. Remember to start at the strut if you need to reset it. |
eric lavine
i see they borrowed the shaft alignment thread on maliboobcrew.com, I thought i copyrighted it lol, at least it will generate traffic to CCF
eric lavine
man im i going threw the hoops today, a guy paid to replace his stringers in a skier and they set the engine about 2 inches forward, to accomadate the increase they pushed the shaft halfway out of the coupling and the prop was riding on the strut
BuffaloBFN
Eric, thanks for keeping us 'straight'.
I had no idea how important alignment was with my '79. Part of why I sold it was it didn't run smoothly...bet I could have fixed it. |
BuffaloBFN
Yikes! |
75 stang
Senior Member Joined: August-11-2008 Location: northwest ohio Status: Offline Points: 475 |
I need to look at mine again, I did it on the trailer over the winter after replacing the bushing but ive still got a growl at the lake. Vacation next week at the lake I may take my tools up and straighten it out...
SNobsessed
75 - My alignment changed by .003 or .004 between checking it on the trailer vs. floating. pretty sure my stringers are OK, so apparently the hull flexes that much.
winniskier
Is a hammer and chisel the way to separate the plates?
Jim
SNobsessed
Hammer & chisel is what these guys have mentioned before, but I have never had to resort to that level of force. Have you tried soaking it in PB Blaster or similar?
I once had a brake rotor that was rusted on - tried everything, including a puller, to remove it. The shop guy hit it for 2 seconds with an air hammer & it fell off. Not recommending this for your boat, but I wonder if it would work. Eric?. |
BuffaloBFN
This comes up over and over. I didn't ever have to break mine loose, but I do think it's fair to say that it will need adjustment if it's rusted shut. |
eric lavine
snob, air hammer and torches are my favorites. my favorite use for the air hammer is u-joints, knocks them right out....once in a while to knock off a prop (with pressure applied), knocking out bearings, it has many uses
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3888 |
Hello,
I used a metal putty knife to get mine apart. I hope this helps, Donald |
