loose rear tow knob, 95 snob |
jbear
Posted: June-28-2008 at 3:35am |
Didn't know you guys had confession...
We've missed you here as well. john |
"Loud pipes save lives"
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
Hi BK:
Just haven't been on here. I probably need to go to confession...I've been fishing more than skiing. Nautique hasn't been out as much this year. We're going in the morning though... I've missed you guys. |
Mullet Free since 93
95 Sport |
92NautiqueSNOB
Newbie Joined: September-17-2007 Location: United States Status: Offline Points: 19 |
I too had trouble with getting to the nylock nut above the tank- but can be done. Next I am going to try tnplicky's idea- I bet that works great! THANKS!
bkhallpass
The Dude! Where you been? Haven't seen you around here in months.
BKH |
Livin' the Dream
The Dude
tnplicky, I like that idea. Thanks!
95 Sport |
emccallum
Platinum Member Joined: August-08-2006 Location: Clarks Hill SC Status: Offline Points: 1084 |
Thanks for the tips! I feel encouraged.
ripster92
Senior Member Joined: April-13-2007 Location: United States Status: Offline Points: 254 |
Not a bad idea...
1992 SN Black w/ Yellow
tnplicky
Senior Member Joined: December-22-2006 Location: C'trl Illinois Status: Offline Points: 333 |
I had the same problem.
I don't know how different your '95 SNOB is from my '95 closed bow, but my rear seat back cusion slides up and out. Then the carpeted panel can be removed giving you access to the fuel tank area. I was able to get a wrench on the pylon nut from underneath w/o removing the tank. I then came up with a "poor man's" solution to keep the rear pylon from coming loose again by making a swivel sleave from a piece of plastic plumbing (drain pipe) |
emccallum
I have the plastic tank....with current gas prices, and the lack of watermy boat is always just about empty, and on the trailer. so I may give it a go this weekend. Thanks guys!
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21133 |
Like ripster said- theres just a hole in the fiberglass with a nut and washer on the other end of that allen head bolt. I think I could tighten mine with the gas tank in, but I have the older style (aluminum) tank.
ripster92
There is a plate and a nylock nut. I believe that you will have to swing the tank out to access it.
emccallum
My rear tow knob on my boat is loose. It has an allen bolt in the top. I have tried to turn the bolt, but it just keeps turning, never tightens. I had the back seat out once before and didnt have good access to the rod because of the fuel tank. So, I gave up as I really never use the knob. can someone explain to me how this thing is attached (does it have an internally threaded rod)? I abviously have to hold something as I tighten the allen bolt, right? Anyone else ever has this same issue? It is different than my 82, which has a lot more access everywhere! Thanks!
