water separator maintenance |
BaccoBouncer
Senior Member Joined: April-25-2016 Location: Essex MA Status: Offline Points: 272 |
Posted: October-24-2022 at 3:35pm |
Does the water separator have a fine particle filter in it? What is best practices for the water separator? Remove and clean each season? Replace? Any inspection to see if it is indicative of any issues?
Thanks, Adam |
'97 21' Sport Nautique
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3893 |
I dump my strainer of water each time I winterize to remove water that can freeze. I also remove any material like weeds if they exist. The strainer is not too fine so sand particles can pass. The lake / River, I boat on seems to have very little weeds. When I take it too White Lake (NC), I would get some weeds in my strainer. So it is going to depend on the body of water you are on. My 1980 did not have a strainer, but I added one. My guess is the older boats did not come from the factory with one. Be sure to keep an eye on the O-Ring when you take it apart. If not done properly you can have air leaks next spring and have overheating.
I think he means the fuel water separator.
Cut him some slack Paul,he's sharing too many Coors Lights with the CQ. To the original post being a 97 I assume we're talking FCC? If your careful of what you put in ie clean cans,hi volume stations it seems you can go for quite some time. But there is a drain plug on the FCC, you could drain it into something and see what comes out. I have seen FCC's corroded inside from not being checked and drained of water
Tomrupp
Groupie Joined: October-14-2021 Location: MI Status: Offline Points: 78 |
Replace the water fuel separator every year. It’s inexpensive maintenance and easy to do. Clean you strainer while your out there.
Tom
94 Ski Nautique Open Bow 351 with Carb 95 Double Decker Aqua Patio with 50hp Honda (3 carbs). |
BaccoBouncer
I converted my EFI to carbs and put a standard separator setup. I can take a picture of it. So should I have a separate fuel filter inline? Sounds like I should put a new one on each year instead of trying to flush it somehow.
Tomrupp
You do not need a separate inline filter. I would replace the water / fuel separator annually. It is possible to flush the water fuel separator, just be careful. Fuel in the hull is dangerous of course.
Tom
BaccoBouncer
Great. Thanks for the info everyone
Donald80SN
