M-600 Quick Fuel Carb |
ncdoubleup
Senior Member Joined: August-08-2010 Location: Statesville, NC Status: Offline Points: 164 |
Posted: June-26-2017 at 10:57pm |
$375 Like new condition. Purchased for my 454 boat motor and was too small. Text or call 704-500-1052.
Description below per Quick Fuel: Carburetor, Q-Series Marine, 600 cfm, Vacuum Secondary, Electric Choke, Satin Black, Single Inlet Quick Fuel Black Diamond Marine Series carburetors feature: * Aluminum fuel bowls with sight glass windows for quick float adjustment * Changeable idle air and high-speed bleeds * PTFE-coated throttle shafts with PTFE bearing ribbons and stainless steel plates * J tubes to prevent spillage * Black Diamond high-temperature satin coating on main body and fuel bowls for enhanced corrosion protection and appearance; coating also provides a 6 percent reduction in fuel temperature * 4-corner idle adjustment (except M-600) * Billet metering blocks with changeable primary idle feed and power valve channel restrictions (except M-600) |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1745 |
Tried sending pm- tried editing post- neither worked.....site must be busy with the spammers tonight😬
I'll try calling tmro. |
ncdoubleup
Sold! Thanks so much!
