Ski Nautique 176 |
Posted: October-28-2016 at 10:11am |
Should run good on 87 octane!
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
Relatively warm. I bucket ran it up to temp in the driveway, changed the oil, and then did the test.
1999 Ski Nautique 196
Was the engine cold or warm
Frankenotter
Just did my first ever compression check on the 176 while putting her away for the season. I was sh!?ing bricks wondering about the outcome for an engine that has 1150 hours, but here are the results.
Cylinder: 1. 115 2. 125 3. 125 4. 120 5. 115 6. 120 7. 125 8. 120 That seems pretty healthy to me. |
^^Yup^^
A stock 330hp 454 will actually struggle to pull a 470 (12.5x15). It'll perform much better with a 13x13 or 13x14 acme (430, 1598, 1458). On a 176 with a 1.23, I don't think ia 470 is going to be enough prop since he's already turning the 422 (12.5x15.5) 4600. That's the sweet spot on a 240hp 351w. |
The prop doesn't know what engine is spinning it.
Big engine with a 1:1 could very well turn the same prop as a smaller engine with a 1.23:1 |
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3620 |
I would think a good prop on a 454 might not be ideal for the 351 engine. The 454 has an extra 100 ft pounds of torque. That is a lot of helpful twist that the small engine could not muster.
phatsat67
HW knows the secrets of the almighty 470
Bet you go faster with a 470.
Great looking boat, looks much younger than 1,000 hours for sure.
Glad you got it dialed in and can have fun with it. I like the color scheme! |
phatsat67
There she goes. There's the rpm you are looking for. I bet GPS will tell you faster.
Frankenotter
I finally got a vacuum gauge yesterday and took her out to tune the carb.
The final result is as follows: 1. 32 advanced on the timing 2. ACME 422 3. 4600 rpm WOT 4. 43 mph on a non-official gps 5. Starts and idles at 600 rpm. I don't think I can ask anything more of a 1040 hr engine. I have been really really happy with this boat. I'll probably keep my eye out for something in a 196 in the next few years, but I'm in no hurry. Thanks for the help with the timing Zach! It sounded much worse than it was. I owe you a few sodas! |
phatsat67
How's it coming along?
Frankenotter
It has been a while since I've updated this thread with current projects. Added new links and I'm working on a timing report with Zach's help.
Cheers! Chris |
Frankenotter
Well I finally got to use my boat for that which it was intended. I got up skiing this week and it preformed really well.
Awesome wake at 15-20 off. I also pulled my friend barefoot and he was pretty happy with the hole shot. I didn't get any pics of me skiing and I have a GoPro coming next week for some shots of the back of the boat underway. We also had a Barefoot 200 out for the day. Who says CC and MC can't get along? |
ny_nautique
I could have sworn someone posted a thread yesterday about potentially selling a 176 and now I can't find it. Maybe he changed his mind?
- Jeff
1999 Ski Nautique |
Frankenotter
Got one of the speedos working. Need to look at the other one a little closer.
Got out for a bit the other day and took requested video of the wake at full power. It's a short clip but it gets the point across. |
Frankenotter
Hey thanks gents. I have a huge task ahead of me with learning about carbs, timing, and props. For the time being I've only had it in the water one time and I'm trying to make arrangements to get the boat closer to my house. Right now I have to make a half day of getting it prepped, launched, recovered, and stored again. In a week and a half ill have it set up to go in the water in about 15 min whenever I want. Once I get to that point I plan to start into the engine performance.
I will be asking some really stupid questions once I start the project because my knowledge in those areas are a little weak. I also have some moderate to severe trailer problems that need attention. Right now my trailer is like a mid evil death blender of jagged metal, rusted screws, and rotted wood. My goal is to have everything fairly complete and functional for Green Lake. Then I hope to find really smart people and chain them to the boat until it runs like a Swiss Watch. Cheers! |
Chris - In addition to checking the carb (secondaries opening all the way), I recommend checking the amount of timing advance. You should be getting at least 28 degrees total advance at 4000 RPM. I have mine set up for 32 degrees at 3000 RPM.
phatsat67
Good job dude!! I always have to use the drill bit method early on in the season from all the dirty water in the lakes/rivers. I take the tube off and blow down through the pickup with compressed air after the drill cleans the pickup.
skutsch
Chris - you should be able to check them now that they are all cleaned out. Have one of those crazy parachute guys "puff" on the pick up, it should cause a needle deflection on the speedos. Its a low pressure system, so no compressed air - HA!
Also I have some left over Collinite for you to try. I'll be back on Friday and can drop it at the hanger then. Any luck finding any threads on tuning carbs? Maybe that should be a new thread. |
If it wasn't for Po's Chris,some of us wouldn't have the boats we do
Frankenotter
Thanks Gary. That's what I did today. I took a bit of safety wire to the pitot and dug out a lot of mud. I think the PO did things just to make me wonder. Both of them were packed solid with mud, the right side was disconnected behind the tank, and the left one was disconnected above the pickup.
Very strange. C |
You will have to check the pickups Chris,they clog easy. You'll have to disconnect the tubing from them and if their clogged you can use a pin or very fine drill bit to clean them out.
Frankenotter
Frankenotter
Oh yea......I forgot to mention,
both speedos do nothing. No indications at all. I know all the tubing is hooked up from when I took the fuel tank out. Any ideas beside replacing all the tubing? Chris |
Frankenotter
Thanks Gary and Jeff!
Steve I think your right about getting more from the engine. Once I get it to a place where it can be in the water for a while then I can start getting into it for sure. Here's a short video from yesterday. Test Run |
ny_nautique
Great job Chris. The swim platform really came out nice.
- Jeff
1999 Ski Nautique |
