Fiberglass lay up Schedules |
fgroce
Senior Member Joined: July-05-2016 Location: Georgia Status: Offline Points: 350 |
Posted: August-02-2017 at 5:33pm |
I also like the epoxy, I reglassed a crushed engine cover and it was very easy to work with.
FGroce
88 Ski Nautique For 28 years Now 2002 Ski Nautique |
mark c
Gold Member Joined: May-09-2012 Location: Massachusetts Status: Offline Points: 534 |
Floors cut out, foams out, most of the rotten wood is out, need to start cutting and fitting the new bulkheads and floor supports and start my most favorite part, sanding the hull. so I can start putting it back together. I only work on it a bit at a time so its going to be a long time project.
JoeinNY
Weight rating between the two cloth and CSM to not line up because cloth is given in sq yards vs mat being given in sq ft. CSM also uses more weight of resin per fabric weight (2x what cloth takes) so it is generally builds bulk quick.
Epoxy over cloth (even large weaves) is not going to delaminate if done anywhere near properly. The binders in typical CSM do make it harder to work with epoxy for sure... I am still working off of a roll of epoxy specific CSM from back when it was available.. You can any of these resins and reinforcements work - but it may take more time and money and end up a bit heavier than a careful selection of materials. |
Skier85
Newbie Joined: January-09-2017 Location: Phoenix, AZ Status: Offline Points: 14 |
Mark, have you started or already completed your stringer job? It sounds like a project to follow!
mark c
I was just describing the factory configuration on my boat. BFN's have a considerably different underfloor construction that a SN.
I will run a couple of layers of 1708 tabbing on the hull and sides of the secondary stringers (the boards on either side of the bilge) and all the floor supports and bulkheads as far forward as the battery box (I'm not going any further forward than that) and then a couple of overlapping layers over the tops to completely encapsulate the wood. All of the wood from the bulkhead behind the battery box aft is getting replaced In my BFN all of the stringers and bulkeads are 3/8" plywood with some 5/8" floor boards forward of the motor box and down the sides of the motor box with some 5/8" strapping that runs on top of the floor supports between the motor box and the sides of the hull. Then foam is placed under these stringers and leveled off at the top level of the stringers. Then theres fiberglass cloth on top of all of that forming the floor and sealing the foam and wood in place. I will used a combination of CSM and 1708 on top of the floorboards and stringers to build the floor up to its finished height. Oh, and I'm using Epoxy resin not Polyester resin. It will be a bit better than what the factory did and I'm not going to be here in another 30 or so years when it might need to be done again. |
Skier85
Mark, thats kind of what I had planned as well, but saw in some of the of the other stringers threads that guys were doing several layers. But with all the other responses it has definitely cleared up the process. Thanks again to all for the input!! Definitely picked the wrong time of year to start a project like this especially in AZ. But summer time fun has lit the fire to get it done sooner.
mark c
The stringers and floor supports in my 87 BFN has about 4" of the roven mat up the side of the floor supports and a couple up and over the two main stringers closest to the keel, and that's it. The floor supports and the two pieces of plywood that form the sides of the bilge (some people call these secondary stringers in a BFN) were not completely wrapped at all (the bilge side was covered with some kind of epoxy but no cloth). Of course that's why I'm scooping them out a mush now 30 year later. The two main stringers are completely covered with the roven mat, and are surprisingly in pretty good shape.
Skier85
Guys thanks for all of the wealth of information, These responses answer a ton of questions that I had! One question I have for DrCC with the cloth that would be the woven 6 or 8 oz material shown in the top picture below correct? Now with 1708 it has some 1.5oz cop on the back you can laminate that right on the hull with proper prep should hold just fine with delam issues correct? Or would you lay one layer of 1.5 and then put the 1708 over that to lock in the two laminations so to speak?
This would be the cloth that DrCC was describing correct... This shows the chop strand backing on the 1708 Say would 2-3 Layers or laminations of 1708 on main stringers be sufficient to give structure to a stringer or would you guys want to add more? |
mark c
the reason CSM does not take to curves and such when used with Epoxy resins is that CSM was originally designed to be used with Poly or Vinyl Ester resins and not epoxy. the binder powder or substrate that holds all the chopped strands together, does not dissolve when used with Epoxy like it does with the poly or vinyl ester resins.. It works just fine on flat surfaces when mixed with epoxy, but if you try to drape it over stringers and such it can be a chore to get it flattened out. CSM when used with poly or vinylester resins will turn clear when they are wetted out as the binder dissolves, It remains more Opaque when used with Epoxy. There are CSM products designed to be used with Epoxy, but most are made for Polyester or Vinylester resins.
DrCC
OK, one last time. Mat adheres long term. Cloth does not.
You cloth users will learn this eventually. edit: except for (long term mat) case of CQ & HW's Martinique. Because it was layed-up on Friday and frame-set on Monday. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
Weight rating between cloth and mat are not comparable for some reason... 1.5oz mat is an order of magnitude thicker than typical cloth (4-8oz).
Many boats built with poly and it should be plenty strong, but boy is it harder to work with compared with epoxy. Hardener ratio (1% vs 1:3) and fumes are 2 big downsides... have had some problems with getting poly and vinyl to cure. Epoxy is always super easy, very tolerant to imperfect mix ratios, etc. |
Hollywood
There are plenty of ways to achieve the strength required. You could build a whole boat exclusively with any fabric available. Optimal laminates take advantage of the unique properties of each material.
Mat is cheap and easy to work with. There is no weave so it's properties are the same in any direction you pull it. It's often used in between layers of thicker fabrics or simply on its own. Mat plus polyester is a cost effective approach. |
Skier85
Skier85
Looks like I will have to read up on how post pictures haha and come back and try again{lol}
Skier85
Skier85
Wisky, I picked up some Polyester from a local shop in town. TRBenj, that makes a lot of sense. I didn't think about about the 1.5 oz as easier to wet out. in my little experiences the mat does lay down and go around difficult corners nicely. But definitely helps me understand why the multiple layers. Thanks for the help guys! I will be glad to arrive to the day when I can hang up the grinder and sander.
CSM = chopped strand mat. Had to look up that acronym.
I can't think of any memorable rebuilds where mat was the primary fiberglass used. Often, it is used in conjunction with cloth. The layups I gravitate towards use a lot of cloth for a few reasons- it has the highest strength to weight, it is thin and easy to work with, uses relatively little resin (per layer), and multiple thin layers is usually much stronger than fewer thick ones. Mixing in a layer or 2 of mat and/or biax (a combination of mat and cloth, where the cloth weave is usually oriented at 45 deg) adds strength in more directions and compliments the cloth nicely- but I don't prefer it as a primary material. Primarily due to its thickness- it doesn't go around corners well and it soaks up a lot of resin so each layer goes fairly slow. |
Wisky Badger
Senior Member Joined: July-02-2015 Location: Wisconsin Status: Offline Points: 218 |
Are you using epoxy resin or polyester resin?
Skier85
So long time lurker and first time poster. I don't want to start start any forum wars here; but I have been looking at a lot of what people have been posting about lay up schedules for new stringers. I have seen a few of the posters tend to run with multiple layers of CSM its my guess, and then biax mat over the top. Is there a particular logic behind going with the CSM? It would seem it would be less labor intensive to say do 3 layers of 1708 vs 6 layers of CSM? But I am no expert. Im just looking to educate myself as I am about to glass some stringers in myself and was planning to do 3 layers of 1708 with CSM over top to seal them in! But got me second guessing reading a couple other threads. Thanks for the help in advance.
